5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 5.9 Andy's 1 Ton ZJ Build "American Standard"
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 12-19-2010, 12:52 PM   #241
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
true, but what about going pre-runner...gana need some stability.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 12-20-2010, 04:01 PM   #242
AgitatedPancake
It's all gunna be about finding the perfect balance haha. In the way long run, you could go with one of those dual rate sway bars. One anti-rock style for rock crawling, one stiffer for driving/prerunning. Just flip a little lock to switch between them!
i'm still feeling kinda sick, but being inside is KILLIN me so I've been doin some work on the 14B today.
Marked the shave lip
Chopped it, delicately sanded with the flap wheel for a while and finished with a file to find high spots. I was actually suprised to see how much imperfection there is in the factory machining of the cast! Makes me even less worried about this lip hah. It came out pretty damn well though.
The welds on the ring gear area of the shave are good, no porosity or lack of penetration anywhere.
I chopped the bottom of this after the pic, and thats about where I'm sitting now
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 12-20-2010, 04:53 PM   #243
biggoofy
Looks sweet man
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 12-20-2010, 04:56 PM   #244
jeep0312
Very pretty. Gunna have enough material to tap for bolt holes?
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2010, 11:08 PM   #245
AgitatedPancake
Thanks guys!
Travis, I definately have enough material on the side pieces, they're still about 1/2" thick. I'll just have to use smaller bolts than OEM. We'll see if I can do anything directly under the ring gear, but I can't drill through weld material so I gotta take it easy haha
Unread 12-21-2010, 08:33 AM   #246
Madmike4790
What are you going to use for the cover? I'm assuming you'll have to chop a cover to match right?
Madmike4790 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2010, 11:27 AM   #247
AgitatedPancake
Yeah mike, Andy has one of the beefy DIY cover kits for me, that's what the ring is from you see in the last pic. I'm going to modify it, and add a bolt hole or 2 back to make sure things don't leak
Unread 12-21-2010, 01:19 PM   #248
jeep0312
Originally Posted by AgitatedPancake View Post
Thanks guys!
Yeah, I was refering to the area you added. It didnt look like you could put the oem bolt sizes back in it.
-Travis-
Unread 12-21-2010, 07:38 PM   #249
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
meah, thats ok....not allot left on this truck that still is OEM.
Unread 12-23-2010, 06:30 PM   #250
AgitatedPancake
Fun day of work today!
I started the day by pressing in the joints, then I tacked the truss on and put some lower link mounts on as close to the cast as I can squeeze em. Might not be enough *fingers crossed*
So I put the radius arms, and made it easy to roll under the truck. I might have to chop and extend the upper arms, running low on thread engagement, and the pinion isn't angled up enough yet. This is because of the lowers mounting directly behind the axle tube instead of below like factory, once again we'll see!
Mmmmm not too shabby hehe
The track bar mount lines up very nicely, but the lowers are fully shortened right now. We'll see how the tires sit in the wheel well with it like this
I'm done workin till after christmas, which is when I'll put a track bar in and really see how everything moves, but so far so good!
Unread 12-23-2010, 06:52 PM   #251
PurpleZJ
lookin good man. i'm lovin the yellow on the arms haha
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 12-23-2010, 07:28 PM   #252
Irish_Assassin
X2
April '11 GCOTM
COLORADO JEEP CLUB #133
www.militaryjeepers.com
Irish_Assassin is offline   Reply With Quote Quick reply to this message
Unread 12-23-2010, 08:57 PM   #253
mtnmarc
do the coil buckets line up with the stock ones on the body?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 12-23-2010, 10:24 PM   #254
AgitatedPancake
Thanks guys!
The coil buckets do line up, you can see the tip of the bumpstop in the 2nd to last picture, lined up pretty well!
Unread 12-23-2010, 11:42 PM   #255
HaViiK
Looks great AP. Wanna move near me?
[SIZE="2"][COLOR="DarkRed"]Steven, New HaViiK[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f197/haviiks-01-wj-slow-build-1067820/"][COLOR="DarkRed"]Black HaViiK:[/COLOR][/URL] [COLOR="DarkRed"]2001 WJ, 4.0, 42re (rebuilt at 100k), 30/35, Rough Country X-Series, JCR Stage 3 Sliders, Yakima Megawarrior & Big Powderhound, Grille Guard, KC Daylighter 130w, Custom Sub Box & 2 Kicker 12" CVR
[/COLOR]
[SIZE="2"][URL="http://www.jeepforum.com/forum/f13/zj-wj-faqs-read-first-contact-mod-changes-additions-591821/"][COLOR="DarkRed"]WJ/ZJ FAQ[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.facebook.com/steven.T.wright"][COLOR="DarkRed"]Facebook. Wheeling stuff in there.[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.youtube.com/user/Thunderheadrcx?feature=mhee"][COLOR="DarkRed"]Youtube Channel. GoPro/Wheeling stuff[/COLOR][/URL][/SIZE]
[QUOTE=rulppa(chat);10944366]whats with people (steve) with those monster sigs. reply is usually like ':E' then 2 pages of signature lol[/QUOTE]
[QUOTE=Sarahdactyl;11226293]THE WINNER IS REDHOTCHILIDOG!!!!111!!1!!!!(OBNXIOUS HUGE BEEFSTEW STYLE FONT) I will PM winner for details[/QUOTE]
HaViiK is offline   Reply With Quote Quick reply to this message
