5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 12 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 5.9 Andy's 1 Ton ZJ Build "American Standard"
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 11-26-2010, 05:53 PM   #166
AgitatedPancake
Andy, hows this for a shave? Muahahaha
I started the shave today...BIG STEPS! Ahhh good stuff. I took just about 3" off the bottom of the diff.
Is this cheating? Haha I've always had the idea...to see your cut lines
I tried the sawzall, said F it and busted out the angle grinder with cutoff wheel. Took like 20 mins to cut off
Little bit of mowhawk action is gunna have to happen haha, it'll be badass!
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 11-26-2010, 06:05 PM   #167
Bama_WJ
That's a pretty good idea with the laser. To bad there is hardly a time when you need to cut a single straight line.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 11-26-2010, 06:10 PM   #168
AgitatedPancake
Thanks! It should be nice for cutting rockers out also . It'll keep you on track perfectly. Even if you just set up the laser to create a trace line to go over with a sharpie. The beauty is it transfers the line across various surfaces accurately, hard to do by hand.
Unread 11-26-2010, 06:29 PM   #169
PurpleZJ
man i cant wait to see how this thing turns out
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 11-26-2010, 06:41 PM   #170
AgitatedPancake
Me either man, me either . There's alot in store for this truck, it's gettin mucho lovin!
Unread 11-26-2010, 07:11 PM   #171
Spike300
oh man i can only imagine
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 11-26-2010, 08:31 PM   #172
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
greg, i know we talked about it in one of our meany meeting before we left..
when you weld on the botton plate, let it extend past the mounting surface of the diff cover... that way it gets a good machining when the cover and axle get machined flat.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 11-27-2010, 12:09 PM   #173
AgitatedPancake
hehe Spike good things are coming.
Andy, that's the plan!
Unread 11-27-2010, 10:01 PM   #174
squashman702
1994 ZJ
What are you plating the bottom of the diff with? 1/2"? Going with a shave kit or are you going to be doing it yourself? Also, are you taking any material off the ring gear?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 11-27-2010, 10:45 PM   #175
AgitatedPancake
1/2" plate I'll be cutting and shaping myself. And yeah, we're taking a decent amount off the ring gear, I'll snap a pic to show how much sometime!
Unread 11-28-2010, 05:02 PM   #176
AgitatedPancake
My Hypertherm Powermax 30 rocked the 1/2" plate for the bottom of the diff, I was way impressed.
Then I got started on plating the shave back in, so far so good!
Unread 11-29-2010, 09:39 PM   #177
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
greg, looking good...allthough im not 100% sure on what you are doing with the center plate?
o, and an FYI.... im thinking of heading down south on the 9th, 2 days before KOH.... so she needs to be good to go by that time.
Unread 11-30-2010, 01:25 AM   #178
AgitatedPancake
Andy I'm taking alot of material thickness off that center section. I've welded all 3 peices together solid, now I'm going to be taking a MASSIVE 8" grinder to it to take that material off and round everything together! There will be more pics before it's welded in for good so you can check it out
Unread 11-30-2010, 03:22 AM   #179
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
sweetness!
Unread 11-30-2010, 02:17 PM   #180
AgitatedPancake
How's this look andy? I've got a little bit more welding and grinding to do, but the shape is there! The inside is getting the same treatment
