5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 4 - JeepForum.com
post #46 of 526 Old 07-13-2010, 08:40 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Any reason the hood vents are on backwards?
forces air in, instead of sucking it out.... i did it within the 1st week i had the jeep, i also cut out the drip trays underneath, so they are straight through.
the heat POURS out of them when im parked.
greg, looks GREAT!
refresh my memory, how do the tnt cossmembers attach to the frame?
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #47 of 526 Old 07-13-2010, 08:55 PM Thread Starter
AgitatedPancake
Thanks errybody! They're actually 1/4" thick haha
Andy, it's bolt on, 4 bolts per side for the front and 2 or 4 per side for the rear. In the front they actually have you weld on some extra reinforcing plates for the additional 2 bolt holes per side. In the last picture you can see the hole i had to cut in the bottom of the stiffener for the threaded nutsert in the frame rail, I figure it's the locator for the rear crossmember. I know you'd probably prefer to have them welded on, but you have to unbolt the front crossmember to do any sort of tranny/tcase work and I don't know a way around that.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #48 of 526 Old 07-14-2010, 07:29 PM Thread Starter
AgitatedPancake
Sooooo....
I got the passenger side together today
Andy, Nice front control arm mounts
Build Thread:
post #49 of 526 Old 07-14-2010, 09:25 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
do they use the factory nut serts?
looking good
build thread:
5.9 ANDY is offline
post #50 of 526 Old 07-14-2010, 09:38 PM Thread Starter
AgitatedPancake
I haven't looked in detail at the mounting of the rear crossmember, and it seems you only have that nutsert on one side so I guess it was for a factory skid plate or something. Looks like there's going to be drilling involved with the rear installation from the looks of things though. I may hold off on installing the rear crossmember for now, as you said a while back it would be in teh way for swapping the tcase when the time comes, and I have no need for it to be installed until then.
Build Thread:
post #51 of 526 Old 07-15-2010, 08:54 AM
ssss4
nice jeep
ssss4 is offline
post #52 of 526 Old 07-15-2010, 09:12 AM
squashman702
1994 ZJ
greg, looks GREAT!
Not sure how effective this is. I think the vent openings are too small to make much of a difference or create any ram air effect.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #53 of 526 Old 07-15-2010, 08:45 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
well, deffinatly not for increaseing power.... i still think it forces in agood amount of cooler air.
i am not worred about it at this point... ill proably buy a reguler hood and sell the 5.9 hood....
build thread:
5.9 ANDY is offline
post #54 of 526 Old 07-15-2010, 11:46 PM Thread Starter
AgitatedPancake
I'd say rock the 5.9 hood man, I've always liked the vents
Alright, I have another way to upload pics, so I got some for ya guys!
First off, I think I finally killed off the rest of the ******* wasps. Andy had told me about (and I had seen for myself) that wasps had taken a liking to his jeep where he had it parked. I *thought* they were pretty much gone when I brought it back, but I kept having a random few buzz in and out of the garage so I went on a hunt...they liked your ******* cowl man!
I killed the **** out of those things! Bigass nest/hive they had going though!
Sorry about the blurry pics, I think this old camera has just about had it. It's a nikon digital that I'd say is a solid...8-10 years old. I've dropped it off the workbench at least a dozen times
These are the inner plates that add 2 bolt holes per side to the front mounting. The bolts are probably 5/8-3/4" thick. The kit also came with bolts to run horizontally though the frame rails, we'll see aboot those. I welded the bracket on pretty damn solid.
LCA mount be gone...gatta love plasma cutters
Aaand a nice blurry longarm shot to finish it off
Build Thread:
post #55 of 526 Old 07-15-2010, 11:59 PM
bigbluezj94
1994 ZJ
what kind of links are you going with? im redoing mine. gonna go 3 link up front and push it out 2" or so with all JJs... gonna redo the rear too... hopfully lift the tank enough into the cab to push the back out 2-3"s as well with all new links... agian JJs. know anyone that wants clayton rear links? already have the front sold.
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
BigBlue build 3/4 ton axles, LAs, 37s
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline
post #56 of 526 Old 07-16-2010, 12:15 AM Thread Starter
AgitatedPancake
This is treks offroad (TNT) longarm kit. The front lowers are 2" .250, and it does the radius arm like everyone else. Props on goin with the 3-link, my WJ's going to get it eventually also. As for the rear, it's a double triangulated 4 link. It's looking like I'm going to have to do some gas tank work when the time comes for the 14 bolt also, but I already have na idea. Before Andy left we crawled around under it and chatted about things, well while we were at it I went and looked at the gas tank. It looks like it might not be all that difficult to push the tank back towards the rear of the ZJ a few inches. When I did the gas tank raise on my WJ I also pushed it back a lil, helps everything fit haha.
Build Thread:
post #57 of 526 Old 07-16-2010, 12:28 AM
bigbluezj94
1994 ZJ
hell yea man. thats good to know about the tank. i havent had time to even look at bigblue lately. just got done moving into a new house so things have been a bit hectic. im tuned in tho man.
also do they just not have the zj kit online or is it ideally the xj kit? i dont see nothin for a zj but the unibody stiffeners.
post #58 of 526 Old 07-16-2010, 12:35 AM Thread Starter
AgitatedPancake
For sure man, we have a lot of fun in store for this ZJ hehe! Also, I'm pretty sure it's a production item, it just might not be on their website. I will say I'm very impressed with then engineering of the entire kit. A lot of design time went into everything and it shows.
Build Thread:
post #59 of 526 Old 07-16-2010, 01:53 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
So there's no way to drop the crossmember for service without taking the arms with it?
ratmonkey is offline
post #60 of 526 Old 07-16-2010, 09:28 AM Thread Starter
AgitatedPancake
The one big downside to this kit, I really wish there was a way around that
Build Thread:
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
