5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 3 - JeepForum.com
post #31 of 527 Old 07-11-2010, 08:23 PM Thread Starter
AgitatedPancake
Haha thanks everyone!
I got back from my gauntlet run and have a little free time finally so I swapped out the blue sub for Andys 5.9 so I could install the frame rail stiffeners and lift!
You usually see the blue sub sitting here..
What's that!? TNT Longarms, TNT Frame rail stiffeners and a Rubicon 241 tcase!?
And JCR 1-ton steering hiding in the background
Getting rid of the surface rust, one clean vs one dirty
This just looks wierd here haha
And i started grinding/cleaning for the frame stiffeners...damn sealant.
Tack welded up in its final position. That's all I had in me for the day!
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #32 of 527 Old 07-11-2010, 09:51 PM
Bama_WJ
I'm digging those steelies.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #33 of 527 Old 07-11-2010, 11:25 PM
mtnmarc
you guys know your stuff. great job. im not too far away, i might ask for some favors. haha.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #34 of 527 Old 07-11-2010, 11:30 PM
squashman702
1994 ZJ
Are you going to full weld the stiffeners?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #35 of 527 Old 07-12-2010, 02:04 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
those wheels and tires are off of a cop car....so i am told.
i sold my old wheels and tires for like $200 and got those as rollers.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #36 of 527 Old 07-12-2010, 06:22 PM Thread Starter
AgitatedPancake
Marc if ya need some work done in the future just let me know!
Squash, yes I am and I have more to add to that with this post
I'm taking a break to let myself and the plasma cutter cool down lol. I think it turned out pretty sick. It's going to give me a crapton of welding area so I can disperse the heat well.
Too bad my camera sucks today, you'd see the centerline of the stiffeners and the holes drawn out.
Couple holes here
Couple holes there
Holes?
Holes.
Build Thread:
post #37 of 527 Old 07-12-2010, 06:49 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i wouldn't have cut that much, about half that many holes would have been more than enough weld area over the uniframe.
i assume you'll be using them for the long arm mount base material. i'm not familiar with the tnt kit.
ratmonkey is offline
post #38 of 527 Old 07-12-2010, 07:29 PM Thread Starter
AgitatedPancake
I know I didn't need that many, but I liked the spacing better this way :P, not too spread out from each other. I'm thinking I'll fully weld the circles, then do stitch welds around the perimiter like normal spacing the stitches to land in between two circles
The TnT kit has a front crossmember for the front radius arms, and a complete seperate rear crossmember for all the rear arms, then the two crossmembers are tied together with a 1/4" plate skidplate
Build Thread:
post #39 of 527 Old 07-12-2010, 07:48 PM
Spike300
OH MY GOD, this is gonna be freakin (cant use the word that i really want to) sweet
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #40 of 527 Old 07-13-2010, 10:43 AM Thread Starter
AgitatedPancake
It should turn out pretty badass I must say! Not quite gunna be an off the shelf build
Today I'm going to clean the rails up all around so I can weld in all the circles, then get these bad mamma jammas mocked up and ready for the final assembly! After these are up I get to install the front and rear crossmembers, and the front radius arm setup!
Build Thread:
post #41 of 527 Old 07-13-2010, 10:51 AM
SILASPRIT
Looks great, cant wait to see where this goes!
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
post #42 of 527 Old 07-13-2010, 04:59 PM Thread Starter
AgitatedPancake
Thanks man, it goes something like this
Took all the everything off the entire frame rail...that took a while lol
Oh snap, that looks good
Some welding done...
Here I was trying to show the stitch welding evenly spaced with the circles
Welding it all up. This setup is going to be damn solid with both crossmembers and future modifications
Build Thread:
post #43 of 527 Old 07-13-2010, 05:07 PM
-cAcHe-
-cAcHe-'s Avatar
Would you happen to have the dimensions for those stiifies? i will be making my own along with other stuff
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #44 of 527 Old 07-13-2010, 05:23 PM
SILASPRIT
Those really look good! What are they, 3/16? I'm sure the frame will be stout now.
-SOLD-
post #45 of 527 Old 07-13-2010, 05:24 PM
squashman702
1994 ZJ
Any reason the hood vents are on backwards?
Think Twice Garage
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
