5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 2 - JeepForum.com
post #16 of 527 Old 06-24-2010, 08:30 PM Thread Starter
AgitatedPancake
Nah I'm not ready for the jeep quite yet man, the blue submarine needs some lovin now. And when I'm workin on your jeep, it's going to be in the blue sub's spot hehe. I gotta get mine ready for my next trip! Gotta pull the tcase and cut the input shaft, with a few other things. There wasn't enough gear oil coming out to tell the color, I'll find out when I dive into it. I figured better to leave it sealed for now.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #17 of 527 Old 06-24-2010, 08:34 PM
Spike300
WOW cant wait to see this build. I bet it going to be killer!
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #18 of 527 Old 06-24-2010, 09:36 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
the best is yet to come.... but it is a supprise... so be patient.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #19 of 527 Old 06-28-2010, 06:20 PM
Spike300
I will good luck, And thank you for serving
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
post #20 of 527 Old 06-28-2010, 07:59 PM
Bama_WJ
Can you really shave a 14b that much?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #21 of 527 Old 06-28-2010, 09:03 PM Thread Starter
AgitatedPancake
Well you can take about 2" off to the bottom of the ring gear, but we're planning a mohawk so the sides will be cut that high, then step down to clear the ring gear.
Kiiiinda like this
Build Thread:
post #22 of 527 Old 06-28-2010, 09:12 PM
Greengc4x4
Doesnt leave much room for diff fluid. lol
Greengc4x4 is offline
post #23 of 527 Old 07-03-2010, 10:45 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
thats why you build the custom cover with a higher fill port.
the solid cover on my 8.8 has me able to put in nearly 5qts.
ratmonkey is offline
post #24 of 527 Old 07-04-2010, 02:41 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
thats the plan... also, when you do this, you have to make sure your breather will still work properly with the higher level of fluid.
build thread:
5.9 ANDY is offline
post #25 of 527 Old 07-04-2010, 04:12 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i tubed it out of the useless abs sensor hole on the 8.8.
post #26 of 527 Old 07-04-2010, 04:29 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
good idea.
im thinking that the angry flapjack might have to drill a hole in the cast housing and then insert a breather or something.
build thread:
5.9 ANDY is offline
post #27 of 527 Old 07-04-2010, 04:35 PM
bigbluezj94
1994 ZJ
i drilled a hole in my SOLID cover for the breather. It still leaks tho when it gets hot. Gonna put a bit less fluid when i change it
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
BigBlue build 3/4 ton axles, LAs, 37s
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline
post #28 of 527 Old 07-04-2010, 10:58 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
ill keep that in mind.
build thread:
5.9 ANDY is offline
post #29 of 527 Old 07-04-2010, 11:44 PM
soul_Less
1994 ZJ
Originally Posted by AgitatedPancake View Post
Theres easier ways to get the doors off a Jeep.
Subcribed.
soul_Less is offline
post #30 of 527 Old 07-05-2010, 09:20 AM
sadass
Nice Job AgitatedPankake ,Thanks! That is an awesome thing you are doing for Andy, I look forward to the build.
And I want to thank Big blue and Andy any any other Service members /Vets that maybe reading this for your Service to our Country .
If you can find the time to fit in yet another forum guy's. Check out Military Jeepers.com
Be Safe fellas
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-15-2016 12:39 AM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 11:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 12:35 PM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 08:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 05:26 AM
