5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 17 - JeepForum.com
post #241 of 527 Old 12-19-2010, 12:52 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
true, but what about going pre-runner...gana need some stability.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #242 of 527 Old 12-20-2010, 04:01 PM Thread Starter
AgitatedPancake
It's all gunna be about finding the perfect balance haha. In the way long run, you could go with one of those dual rate sway bars. One anti-rock style for rock crawling, one stiffer for driving/prerunning. Just flip a little lock to switch between them!
i'm still feeling kinda sick, but being inside is KILLIN me so I've been doin some work on the 14B today.
Marked the shave lip
Chopped it, delicately sanded with the flap wheel for a while and finished with a file to find high spots. I was actually suprised to see how much imperfection there is in the factory machining of the cast! Makes me even less worried about this lip hah. It came out pretty damn well though.
The welds on the ring gear area of the shave are good, no porosity or lack of penetration anywhere.
I chopped the bottom of this after the pic, and thats about where I'm sitting now
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #243 of 527 Old 12-20-2010, 04:53 PM
biggoofy
Looks sweet man
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #244 of 527 Old 12-20-2010, 04:56 PM
jeep0312
Very pretty. Gunna have enough material to tap for bolt holes?
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #245 of 527 Old 12-20-2010, 11:08 PM Thread Starter
AgitatedPancake
Thanks guys!
Travis, I definately have enough material on the side pieces, they're still about 1/2" thick. I'll just have to use smaller bolts than OEM. We'll see if I can do anything directly under the ring gear, but I can't drill through weld material so I gotta take it easy haha
Build Thread:
post #246 of 527 Old 12-21-2010, 08:33 AM
Madmike4790
2014 JK Wrangler
What are you going to use for the cover? I'm assuming you'll have to chop a cover to match right?
Madmike4790 is offline
post #247 of 527 Old 12-21-2010, 11:27 AM Thread Starter
AgitatedPancake
Yeah mike, Andy has one of the beefy DIY cover kits for me, that's what the ring is from you see in the last pic. I'm going to modify it, and add a bolt hole or 2 back to make sure things don't leak
Build Thread:
post #248 of 527 Old 12-21-2010, 01:19 PM
jeep0312
Originally Posted by AgitatedPancake View Post
Thanks guys!
Yeah, I was refering to the area you added. It didnt look like you could put the oem bolt sizes back in it.
-Travis-
jeep0312 is offline
post #249 of 527 Old 12-21-2010, 07:38 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
meah, thats ok....not allot left on this truck that still is OEM.
build thread:
5.9 ANDY is offline
post #250 of 527 Old 12-23-2010, 06:30 PM Thread Starter
AgitatedPancake
Fun day of work today!
I started the day by pressing in the joints, then I tacked the truss on and put some lower link mounts on as close to the cast as I can squeeze em. Might not be enough *fingers crossed*
So I put the radius arms, and made it easy to roll under the truck. I might have to chop and extend the upper arms, running low on thread engagement, and the pinion isn't angled up enough yet. This is because of the lowers mounting directly behind the axle tube instead of below like factory, once again we'll see!
Mmmmm not too shabby hehe
The track bar mount lines up very nicely, but the lowers are fully shortened right now. We'll see how the tires sit in the wheel well with it like this
I'm done workin till after christmas, which is when I'll put a track bar in and really see how everything moves, but so far so good!
Build Thread:
post #251 of 527 Old 12-23-2010, 06:52 PM
PurpleZJ
lookin good man. i'm lovin the yellow on the arms haha
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #252 of 527 Old 12-23-2010, 07:28 PM
Irish_Assassin
X2
April '11 GCOTM
COLORADO JEEP CLUB #133
Irish_Assassin is offline
post #253 of 527 Old 12-23-2010, 08:57 PM
mtnmarc
do the coil buckets line up with the stock ones on the body?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #254 of 527 Old 12-23-2010, 10:24 PM Thread Starter
AgitatedPancake
Thanks guys!
The coil buckets do line up, you can see the tip of the bumpstop in the 2nd to last picture, lined up pretty well!
Build Thread:
post #255 of 527 Old 12-23-2010, 11:42 PM
HaViiK
Looks great AP. Wanna move near me?
Steven, New HaViiK
2001 WJ, 4.0, 42re (rebuilt at 100k), 30/35, Rough Country X-Series, JCR Stage 3 Sliders, Yakima Megawarrior & Big Powderhound, Grille Guard, KC Daylighter 130w, Custom Sub Box & 2 Kicker 12" CVR
Originally Posted by rulppa(chat) View Post
whats with people (steve) with those monster sigs. reply is usually like ':E' then 2 pages of signature lol
Originally Posted by Sarahdactyl View Post
THE WINNER IS REDHOTCHILIDOG!!!!111!!1!!!!(OBNXIOUS HUGE BEEFSTEW STYLE FONT) I will PM winner for details
HaViiK is offline
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
