5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 16 - JeepForum.com
post #226 of 526 Old 12-07-2010, 06:40 PM
jeep0312
You do some beautiful work sir.
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #227 of 526 Old 12-08-2010, 07:38 AM
squashman702
1994 ZJ
Any reason for not doing a triangulated rear shock setup like Clayton's offers? Seems you'd get the most flex out of the 4 link rear that way.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #228 of 526 Old 12-08-2010, 08:42 AM Thread Starter
AgitatedPancake
Thanks Travis!
I think the triangulated shocks will happenin the next phase, it would be fun to design the upper crossmember with the torchmate muahahaha . The plasma cutter makes it easy to zip off these shock brackets when the time comes!
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #229 of 526 Old 12-08-2010, 05:24 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
non-traingulated and spaced as wide as possible is MUCH more stable. being on a double tri you need all the extra stability that can offer.
ratmonkey is offline
post #230 of 526 Old 12-11-2010, 04:48 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
that is a good point on the stability, even though we will have a rear sway bar, its only going to be connected when on road, soon as we hit the trails, its off.
speaking of wich... anyone selling some JKS quick disco's?
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #231 of 526 Old 12-12-2010, 08:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I'm going to use a full traction tj bar in the back. Should work well against the anti rock.
post #232 of 526 Old 12-17-2010, 07:01 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
will you be leaving it connected while wheeling?
build thread:
5.9 ANDY is offline
post #233 of 526 Old 12-18-2010, 06:42 PM Thread Starter
AgitatedPancake
I have a couplea parts, for both builds here haha.
Build Thread:
post #234 of 526 Old 12-18-2010, 06:48 PM
Spike300
i dont think you can count hats more than a couple
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #235 of 526 Old 12-18-2010, 07:09 PM Thread Starter
AgitatedPancake
Haha! The bearings to the left, and the lower 3 left boxes are all for my 609 build, the rest is for Andy!
His stuff:
2 lockers
2 gear sets
2 install kits
set of wheel bearings seals
2 yokes
pair of 14 b shafts
front driveshaft
2 hydraulic rams
2 fresh calipers/brakes for the D60
Build Thread:
post #236 of 526 Old 12-18-2010, 08:46 PM
jeep0312
Wow!!
-Travis-
jeep0312 is offline
post #237 of 526 Old 12-19-2010, 12:44 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
absolutely.
after riding in a clayton's zj with everything disconnected. sirfuego's buggy, and wheeling with the anti-rock. it definitely needs the stability offered by sway bars in both ends. for this area anyways.
post #238 of 526 Old 12-19-2010, 02:21 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
ill keep that in mind... i have been reading that a swaybar is a big help in the stability department... time will tell waht i decide to do, mabe wheel with one connected, one not.
we will see.
build thread:
5.9 ANDY is offline
post #239 of 526 Old 12-19-2010, 09:09 AM Thread Starter
AgitatedPancake
Amdy, that's really going to be a personal preference thing. Out here on the west coast we don't have to use momentum on obstacles like a lot of the east coasters do. When you start using a lot of momentum is when the body roll gets a little scary.
If you do decide it's too soft without sway bars though, those aftermarkets are probably going to be a little too stiff for you, limiting fex a pretty good amount. We'll have to find a perfect middle ground!
Build Thread:
post #240 of 526 Old 12-19-2010, 11:53 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
enough control on road with your set up is going to limit you off. It's the nature of the double triangulated long arms.
I get decent on road roll in mine now, but at slow speeds the anti rock is nice. I expect when I finally get around to hooking the rear up it will smooth out the on road shennanigans.
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
