5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 15 - JeepForum.com
post #211 of 527 Old 12-03-2010, 05:18 PM Thread Starter
AgitatedPancake
Yeah actually I have to figure out if there needs to be some proportioning valve work going from discs in the rear to drums!
I'm setting up for a mock install of the rear axle to get the coil buckets lined up and burned in, and the sway bar mounts! I gotta poke through the parts pile and make sure I have brackets for that bad mamma jamma. The housing is going to get machined before I start on the assembly, and that should be happening soon! If I get the rest of the brackets on the 14 bolt and still haven't gotten it machined yet, I'll just move onto the front axle so there's no slow down in progress.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #212 of 527 Old 12-03-2010, 05:26 PM
squashman702
1994 ZJ
What's the reasoning behind not going to disc?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #213 of 527 Old 12-03-2010, 06:00 PM Thread Starter
AgitatedPancake
cost as of now, last time I talked to Andy about it I think discs might be in the next stage of the build?
The 14B is now hung under the jeep! I'm stopping for the day, but I figure I'll do the brackets over the weekend, and we'll see what else! The machinist hasn't called me about the front axle truss...he's slackin!
Build Thread:
post #214 of 527 Old 12-03-2010, 07:28 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
cost, that is the reason that we are not doing disk right now..... not for the cost of just rotors, calipers and brackets.... thats not that bad.... but what about a parking break???
the solution that i like the most is a disk at the out put of the t-case. i have been speaking with jesse at high angle drive line, he dose not have a bracket for my application, so i will be making my own.. it also needs a special output flange, so that will have to be orderd as well.
to be honest, im keeping the drums for now for only 2 reasons, its easy to set up a parking brake, and they are heavy as ****... so its good for COG.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #215 of 527 Old 12-03-2010, 07:54 PM Thread Starter
AgitatedPancake
Andy, the Torchmate should be able to help us perfectly with that bracket . You might not even need a new yoke/flange if we can make an adapter from the flange bolt pattern to the rotor bolt pattern!
Build Thread:
post #216 of 527 Old 12-03-2010, 08:53 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
****ing awsome!!!!
build thread:
5.9 ANDY is offline
post #217 of 527 Old 12-03-2010, 11:47 PM Thread Starter
AgitatedPancake
Mmmm here is a little more of what I did today!
Build Thread:
post #218 of 527 Old 12-04-2010, 02:30 PM
mtnmarc
what coil buckets are you going to use? or are you gunna fab some yourself?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #219 of 527 Old 12-04-2010, 07:27 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
planing on using the ones from tnt customs...
as for how we greg will work on the retainers.... i have no ****ing clue.
build thread:
5.9 ANDY is offline
post #220 of 527 Old 12-04-2010, 09:57 PM
lloyd877
This build is amazing, I am wondering how AP is going to fab up the dif cover to fit. can't wait to see the finished product.
WJ 2001 4.0L
5.9 ZJ AKA Race Jeep 30" BFGoodrich ATs (Sold)
lloyd877 is offline
post #221 of 527 Old 12-04-2010, 10:46 PM Thread Starter
AgitatedPancake
Yup theres actually a coil bucket sitting on the passenger side axle tube in the pics!
Andy, I'll probably do similar to what I did in the front. Put a bolt through the center hole in the coil buckets facing upward, then have a little plate that lays ontop of the first set of coils with a matching bolt hole, crank down a nut on top of both and it sandwiches the coil down to the bucket firmly. No issues with my identical front setup from ballistic at all!
Lloyd, Just a little bending, trimming and grinding...it'll be nice
Build Thread:
post #222 of 527 Old 12-05-2010, 01:27 AM
mtnmarc
i just got my ballistic coil buckets and they seem like they shouldnt have a problem. when is the 9 inch going in the front?
mtnmarc is offline
post #223 of 527 Old 12-05-2010, 01:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
1978 caddy eldorado calipers have built in parking brake. all you need is cables. ALL of the disc brake bracket kits out there are designed to work with them or the front 3/4ton chebby calipers(same mounting boss and offsets)
ratmonkey is offline
post #224 of 527 Old 12-05-2010, 01:32 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
rat, that is kinda my plan, to use the elderado calipers....but not on the rear axle, im stll going to go for the chebby 3/4 ton... however. there will be an elderado caliper on the drive line to act as a parking brake.... and an additional brake on the hydralic brake system.
i plan on beaging able to stop very well with this combo....
and yes, master cylinders and boosters will be upgraded.
build thread:
5.9 ANDY is offline
post #225 of 527 Old 12-07-2010, 06:09 PM Thread Starter
AgitatedPancake
Andy we might end up needing to do something about your booster/master with that combo, as it's going to require a little extra volume to move everything around.
Well I did a decent amount of work today, short day of school so I could play catchup for the weekend haha.
Front crossmember went in
I started testing absolute maximum uptravel of the 14 bolt with the TnT arms fully shortened. Even with them short I think the axle is back more than stock, so I should be good. There is no chance the shocks will even let it compress this much!
Besides, if you go up that far you have other issues to worry about
Sorry the pic is blurry, but I tacked the coil mounts in place and just set the coils in to see how it looked, segzy! BTW Andy the hole in the center of the spring bucket already has a nut welded in! All I have to do is find the right bolt and we'll have out spring clamps.
Shock mounts were next, they gradually slope down just slightly below the axle tube, trying to get max possible uptravel outta this thing. The rear axle is pretty much done now, only the sway bar mounts left, but that'll be one of the last things to get done.
I also took the wire wheel to all the arms and joints of the front suspension, knocked all the surface rust off getting them ready for paint! I called the machinist today to get on their *** about the front truss, it's frustrating the hell outta me. I told him if he can't get it done SOON (next day or two) I'm going to need to take it back and have someone else do it, and at that point he'd be losing all my future business so lets hope it doesn't get there. I'm just running out of things to do that aren't front axle related heh.
Build Thread:
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
