5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 12 - JeepForum.com
post #166 of 527 Old 11-26-2010, 04:53 PM Thread Starter
AgitatedPancake
Andy, hows this for a shave? Muahahaha
I started the shave today...BIG STEPS! Ahhh good stuff. I took just about 3" off the bottom of the diff.
Is this cheating? Haha I've always had the idea...to see your cut lines
I tried the sawzall, said F it and busted out the angle grinder with cutoff wheel. Took like 20 mins to cut off
Little bit of mowhawk action is gunna have to happen haha, it'll be badass!
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #167 of 527 Old 11-26-2010, 05:05 PM
Bama_WJ
That's a pretty good idea with the laser. To bad there is hardly a time when you need to cut a single straight line.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #168 of 527 Old 11-26-2010, 05:10 PM Thread Starter
AgitatedPancake
Thanks! It should be nice for cutting rockers out also . It'll keep you on track perfectly. Even if you just set up the laser to create a trace line to go over with a sharpie. The beauty is it transfers the line across various surfaces accurately, hard to do by hand.
Build Thread:
post #169 of 527 Old 11-26-2010, 05:29 PM
PurpleZJ
man i cant wait to see how this thing turns out
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #170 of 527 Old 11-26-2010, 05:41 PM Thread Starter
AgitatedPancake
Me either man, me either . There's alot in store for this truck, it's gettin mucho lovin!
Build Thread:
post #171 of 527 Old 11-26-2010, 06:11 PM
Spike300
oh man i can only imagine
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #172 of 527 Old 11-26-2010, 07:31 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
greg, i know we talked about it in one of our meany meeting before we left..
when you weld on the botton plate, let it extend past the mounting surface of the diff cover... that way it gets a good machining when the cover and axle get machined flat.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #173 of 527 Old 11-27-2010, 11:09 AM Thread Starter
AgitatedPancake
hehe Spike good things are coming.
Andy, that's the plan!
Build Thread:
post #174 of 527 Old 11-27-2010, 09:01 PM
squashman702
1994 ZJ
What are you plating the bottom of the diff with? 1/2"? Going with a shave kit or are you going to be doing it yourself? Also, are you taking any material off the ring gear?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #175 of 527 Old 11-27-2010, 09:45 PM Thread Starter
AgitatedPancake
1/2" plate I'll be cutting and shaping myself. And yeah, we're taking a decent amount off the ring gear, I'll snap a pic to show how much sometime!
Build Thread:
post #176 of 527 Old 11-28-2010, 04:02 PM Thread Starter
AgitatedPancake
My Hypertherm Powermax 30 rocked the 1/2" plate for the bottom of the diff, I was way impressed.
Then I got started on plating the shave back in, so far so good!
Build Thread:
post #177 of 527 Old 11-29-2010, 08:39 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
greg, looking good...allthough im not 100% sure on what you are doing with the center plate?
o, and an FYI.... im thinking of heading down south on the 9th, 2 days before KOH.... so she needs to be good to go by that time.
build thread:
5.9 ANDY is offline
post #178 of 527 Old 11-30-2010, 12:25 AM Thread Starter
AgitatedPancake
Andy I'm taking alot of material thickness off that center section. I've welded all 3 peices together solid, now I'm going to be taking a MASSIVE 8" grinder to it to take that material off and round everything together! There will be more pics before it's welded in for good so you can check it out
Build Thread:
post #179 of 527 Old 11-30-2010, 02:22 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
sweetness!
build thread:
5.9 ANDY is offline
post #180 of 527 Old 11-30-2010, 01:17 PM Thread Starter
AgitatedPancake
How's this look andy? I've got a little bit more welding and grinding to do, but the shape is there! The inside is getting the same treatment
Build Thread:
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
