5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 10 - JeepForum.com
post #136 of 526 Old 11-10-2010, 06:57 PM
GraKee99
Rapist Wit
GraKee99's Avatar
I weld quite a bit at work and I have never seemed to max out the cycle. I start to go cross eyed after a little bit.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #137 of 526 Old 11-10-2010, 10:20 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I tend to burn through my gloves before my lincoln gets to its max.
ratmonkey is offline
post #138 of 526 Old 11-11-2010, 08:27 AM Thread Starter
AgitatedPancake
Yeah pretty much! When I have it cranked my gloves can get aweful hot...and I have thick stick welding gloves not mig gloves. Though I will say an old welding technique led to a fried finger on these gloves hahaha
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #139 of 526 Old 11-11-2010, 08:39 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You not wearing leathers for welding? A tack here and there and I'll use mechanic gloves, but if I am doing more then that, ouch!
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #140 of 526 Old 11-11-2010, 08:53 AM Thread Starter
AgitatedPancake
Well I wear leather gloves, but no jacket :P. I used to use mechanix too, but they were too easy to melt a hole through with slag balls haha!
Build Thread:
post #141 of 526 Old 11-11-2010, 04:27 PM Thread Starter
AgitatedPancake
I got a few pics, the truss is going together great right now! I actually have the top layer on now, but no pics. Letting everything cool down a little bit, theres a LOT of weld to put that truss together!
Inner layer
Sorry for the sideways pic, but it shows: I welded the tubes, put the truss on, welded the outside of the truss leg then welded the inside to cast. It is SOLID.
It looks a little wierd, but here's the top of the diff. It's definately solid, the hammer marks and little slag bits just take away from it!
More to come later once it's all welded!
Build Thread:
post #142 of 526 Old 11-11-2010, 04:44 PM
mtnmarc
thats nice to have to crossmember. i looked for it on the tnt site, but couldnt find it.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #143 of 526 Old 11-11-2010, 05:46 PM Thread Starter
AgitatedPancake
Hmmm well it's the kit they offer for ZJ's, one crossmember for the front links and tcase, one crossmember out back for the rear links and to act as a skidplate mount!
It's not going anywhere...hahaha
Build Thread:
post #144 of 526 Old 11-11-2010, 07:17 PM
squashman702
1994 ZJ
Welds look really good.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #145 of 526 Old 11-11-2010, 08:49 PM
ArloGuthroJeep
Mr. Hyde!
Lots of welds...how long did it take you? Still hot?
post #146 of 526 Old 11-11-2010, 10:29 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I've got a denim welding coat for the easy stuff and a 12lb leather bike jacket for overhead. I burn through welding gloves every once in a while. Makes a nice color burn.
It's going to be hot till sunday.
post #147 of 526 Old 11-11-2010, 10:36 PM Thread Starter
AgitatedPancake
I put like 3-4 hours of welding into it, including preheating/postheating the cast and all that! It stayed pretty hot because of the cast heating, but I tried to space the truss welding with some intervals to spread the heating, still pretty dang warm for hours!
Build Thread:
post #148 of 526 Old 11-12-2010, 04:58 PM Thread Starter
AgitatedPancake
I did the lower control arm mounts and a little more cast welding today. Coil buckets will probably wait till I get it under the jeep and find the best rotation vs. pinion angle. Next things on the list right now are swapping in the 241 tcase and installing the rear crossmember so I can actually hang the 14 bolt!
I have to say...this weld felt GOOOOOOD.
Spot for table? Hmmm hahaha
Build Thread:
post #149 of 526 Old 11-17-2010, 06:53 PM Thread Starter
AgitatedPancake
Well, I pressed that ****ing 241 up into position 5 times today. First couple times the tranny was too high in the tunnel and I couldnt get it on, the other times were vice versa AGH. Haha. Aaaanyways, I finally got it and bolted the skid and rear crossmember up! This is just for measuring, then it comes back down to get the welded inserts put in, then the 44a comes out and i'll probably do a complete mock install, then the 14 bolt comes back out for the shave!
Build Thread:
post #150 of 526 Old 11-19-2010, 06:33 PM Thread Starter
AgitatedPancake
Well I talked to TnT today about the weld in inserts for the rear, and found out this is actually a pre-production kit haha! They haven't officially released these yet, but are expecting to in the next couples months so this is a treat for you guys! I will say that I personally think the double triangulated rear is the best setup on the market! Can't wait to really drive it and test it out.
I bolted everything together today to get the location of the holes I need for the weld in threaded inserts for hte rear crossmember. My call to TnT was to talk about this: If your doing it on just a frame rail you drill a 3/4" hole and the threaded insert's little step sits on the surface, but if you have the stiffeners also you want to drill the frame rail to 3/4" but the stiffener to 1" to sink the entire threaded insert into the stiffener for a flush mount.
(Yes, one of them landed in a hole I cut. I'm not too worried about it, I can still get a good amount of weld to the 1/4" plate and these were designed to be used with the stock frame rail anywhoo!)
Build Thread:
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
Solomon8718's build thread - "Muddy Gorilla" solomon8718 Grand Cherokee General Discussion 36 01-20-2011 11:35 AM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
