5.3, 4l60 zj - Page 10 - JeepForum.com
post #136 of 692 Old 03-08-2012, 10:04 PM
aircruiser
aircruiser's Avatar
I would assume so haha and probably wouldn't pass the exhaust test at gilbert. Plus wouldn't that hurt back pressure?
aircruiser is offline
post #137 of 692 Old 03-08-2012, 10:09 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
It would be semi quiet with a 40 muffler. Just trying to figure out how to fit all this crap in such a tight space. Plus I wouldn't have to worry about smashing it if it was up front.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #138 of 692 Old 03-08-2012, 11:36 PM
aircruiser
aircruiser's Avatar
True idk I have never seen it done so I can't comment on that to much. Would block huggers even fit?
post #139 of 692 Old 03-09-2012, 06:15 AM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
I'll know more today. Once the engine is in its final location I can figure it out. If nothing else I'll cut my manifolds and get through there with 2 in pipe.
post #140 of 692 Old 03-09-2012, 03:18 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Engine and trans mounts made. Started on the manifolds, don't laugh it's stupid tight, and I'm cheap. Lol. Air filter isn't completely mounted but you get the idea. Had a bit of a wiper throttle issue as well. That problem is solved by now I have a driver wiper. Lol.
image-462301739.jpg   image-4083348288.jpg   image-3861581374.jpg   image-321385217.jpg   image-2911087078.jpg
image-2405674814.jpg   image-2768298818.jpg   image-2903790470.jpg   image-1863969293.jpg
post #141 of 692 Old 03-09-2012, 05:26 PM
Foundrydude
You're a total pu$$y if it doesn't have exhaust stacks pointing straight up with a pair of clinkers
Truck is really coming together nicely. Well thought out, and very cool. Those doors look like they'd keep you well ventilated on the streets of connecticut.
Good luck with it.
Foundrydude is offline
post #142 of 692 Old 03-09-2012, 05:58 PM
aircruiser
aircruiser's Avatar
There ya go thats one way to fix it haha
post #143 of 692 Old 03-09-2012, 06:36 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Good luck with it.
Lol. No actually I'm a guy with 3 kids and like riding trails, not talking to game wardens. Thanks for the compliments. I'm a farm boy with lots of scrap iron, and my shop is 15 miles from steel, so I'm doing the most with what I have here lol. It's not the most trick, water jet cut custom build, but it's built, and If it breaks I'll make it better.
post #144 of 692 Old 03-09-2012, 06:45 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Need to pick up some exhaust tubing to tie it together. Finished my home made 241 clocking ring lol, I'm sweating like a pig from that job. Last pick is close to ride height as it will droop 9 more inches.
image-245250420.jpg   image-3576078906.jpg   image-1399763052.jpg   image-551404975.jpg
post #145 of 692 Old 03-09-2012, 08:03 PM
aircruiser
aircruiser's Avatar
Maybe I missed it but are you planning on still running fenders and a front clip and hood or no?
post #146 of 692 Old 03-09-2012, 08:34 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Yes. It's just a lot easier working on everything with them off. I put the hood on again tonight. Next project is making it a cowl induction looking hood to clear the alternator and intake. Fenders will be the last thing to go back on, but they are one bolt and 2 rivets so that will be the easiest thing I've done on it lol.
post #147 of 692 Old 03-09-2012, 08:47 PM
1stblack97ZJ
Lookin good man!!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #148 of 692 Old 03-09-2012, 08:54 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Thank you sir.
post #149 of 692 Old 03-10-2012, 07:20 AM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Headed to Fargo. Decided I'm going to run copper pipe for the rear mount rad lines, should get rid of some heat, and then I can solder the corners instead of welding it all. Also picking up the exhaust pipe needed to piece this pig back together.
post #150 of 692 Old 03-11-2012, 02:16 PM
nickpequignot
I was wonderin what garmin gps you have. I'm thinkin about getting one and that ecoroute hd to put in my zj.
nickpequignot is offline
