4x4Jeep's build thread.. - Page 20 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 4x4Jeep's build thread..
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 09-27-2013, 07:04 PM   #286
4x4Jeep
been getting tons of wobbling/vibrations from the front wheels at 50+ mph. might need to get my wheels balanced but the bigger problem was the wheel bearing was bad. had replaced the driver's side a while back but was time for the passenger side. bought a Raybestos for $56. worked on that today, now just need an alignment and possibly balance the wheels. haven't driven it much yet to see if that solved the problem i was having.
Build - http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031 - SOLD
4x4Jeep is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 11:07 AM   #287
TeeJay4490
You dont have to get an alignment because of a wheel bearing
-TJ
1999 Grand Laredo 4x4: [SIZE="2"]Whats left of a front bumper - JK Saharas' with 33's - 4 in. Rough Country lift - HID conversion - Double cardon conversion - TJ gas cap mod - Recovery points added - Painted cladding and grill - Skid plates - All moog suspension- Roof Rack -CB radio - Cut and trimmed fenders[/SIZE]
[url]http://www.jeepforum.com/forum/f197/tjswj-build-thread-1438516/[/url]
[url]http://wjjeeps.com/[/url]
TeeJay4490 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 06:24 PM   #288
4x4Jeep
no but i need one bad...pulls to the right and my steering wheel has a ton of play in it.
Unread 09-29-2013, 03:14 PM   #289
Newfive
I am about to do that same job on both sides... saving my nickels to get good ones... plus I need to put in some axle seals so all that has to come out anyhow.
Newfive is offline   Reply With Quote Quick reply to this message
Unread 09-29-2013, 05:11 PM   #290
4x4Jeep
the one i did a few months ago was a Timken and paid about $90 for it, but this was something i needed done soon and didn't have much money. the Timken's i believe are the good quality ones.
Unread 09-29-2013, 11:37 PM   #291
TeeJay4490
Touche sir lol
-TJ
Unread 09-29-2013, 11:38 PM   #292
TeeJay4490
And I just recognized your Jeep from Fl4x4. Youre going to have to come ride next time im in Orlando sir.
-TJ
Unread 11-06-2013, 10:12 PM   #293
4x4Jeep
so haven't updated in a while. been putting off jeep work cause i was spending my money on this (built from scratch by me )
week ago had my tires balanced and a much needed align,ent
replaced my signal stalk cause my turn signals stopped working
the other day i started the jeep and there was a loud whining noise opened the hood and my serpentine belt was shredding. so went to go change it out and broke the tensioner by turning it the wrong way...oops
so i had it towed to my local shop he replaced it for me and replaced the power steering pulley which was cracked for the past 3 years. also had some other things inspected and got quoted on some work.
i was having a very bad wobble at 50+ mph couldn;t figure out what was wrong, mechanic said it might be the trackbar nut was loose. so when i got home i tightneed it and what do you know it fixed it. other things i got quoted on where front/rear pinion seals...about $233 for both. also my TC linkage needs replacing, part is $160ish....i'll probably do that myself. i think this is all i need...http://www.novak-adapt.com/catalog/shifters/sk2xc.htm
and i hope to buy some much needed tires/wheels in a few months since i make a lot of extra dough for peak season.
Unread 11-26-2013, 09:32 AM   #294
4x4Jeep
so i installed another moog SS and cleared up some of my wobble, but still does it around 60 mph.
Unread 12-06-2013, 11:14 AM   #295
4x4Jeep
pictures from last week's fun with some FJ Cruisers
Unread 12-06-2013, 11:23 AM   #296
4x4Jeep
parts i got in yesterday
rear rotors
drivers' axle shaft
Unread 12-09-2013, 10:05 AM   #297
4x4Jeep
a friend is selling his IRO adj. short arms, might be buying the rears + RC a-arm off him soon. and then later on i'm thinking about upgrading to front long arms and Clayton 4.5" springs
Unread 12-09-2013, 09:59 PM   #298
Newfive
I am doing both front hubs in few days... waiting on order to arrive... found both fronts for $40 each from U.S. manufacturer in Kentucky.
http://www.jeepforum.com/forum/f197/newb-his-wj-1487580
Unread 12-10-2013, 09:40 AM   #299
4x4Jeep
you don't know the manufacturer?
Unread 12-10-2013, 10:45 AM   #300
OverlandSummitt
Great looking Cherokee!
OverlandSummitt is offline   Reply With Quote Quick reply to this message
