4x4Jeep's build thread.. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 4x4Jeep's build thread..
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-02-2012, 09:52 AM   #16
mrJ
2002 KJ Liberty
Perfectly fine. Addco rear sway
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 03:40 PM   #17
alwaysHI
2003 WJ
ahhh I'm still with OEM...i know that'll make a difference
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 03:30 PM   #18
4x4Jeep
Originally Posted by mrJ View Post
There's 32's on CL right now. Brand new I think. And you don't need discos. I just took the front sway bar off
you run like that daily driving?
Got my jeep back today...finally. apparently what was causing so many problems with the overheating was the radiator and the trans. cooler were clogged with a lot of dirt, and they overlooked it. i've always pressure washed everything after going through mud, but obviously didn't do a good enough job. lesson learned. they put a new cooler on it, and he raised it for me so it is less likely to get dirt/mud in it.
Build - http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031 - SOLD
4x4Jeep is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 04:58 PM   #19
mrJ
2002 KJ Liberty
Good deal. I'm gonna check mine.
Yeah man, brick roads round here are ****ing brutal.ill let you drive it next trip...its tighter now then it was with the front connected and the one broken rear sway link. The addco is TIGHT. Doesn't make sense, but whatever's clever
Unread 04-08-2012, 03:06 PM   #20
4x4Jeep
from this weekend
next day
Unread 04-09-2012, 08:52 AM   #21
peytonimor7
GET A REAR RECOVERY POINT! I hate to see you strap around the axle haha.
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline   Reply With Quote Quick reply to this message
Unread 04-09-2012, 11:20 AM   #22
4x4Jeep
it's not on the axle...i have a tow hook there. my axle was buried any way.
Unread 04-09-2012, 11:26 AM   #23
peytonimor7
I have really bad eyes
Unread 04-09-2012, 11:29 AM   #24
4x4Jeep
actually it's not even visible in the pic cause everything's dark/black under there.
Unread 05-04-2012, 01:45 PM   #25
4x4Jeep
just ordered some KC driving lights for the brush guard, along with some much needed front wipers.
jeep is actually down at the moment. somethings wrong with the brakes. will need to get a free inspection, depending on what it needs, i'll decide if i can do it or have the shop do it.
and i recently found out that i have the Akebono's on my '01...
Unread 05-05-2012, 07:27 AM   #26
mrJ
2002 KJ Liberty
Akebono is good. Holler if you need help doin the brakes. Really easy
Unread 05-05-2012, 06:52 PM   #27
4x4Jeep
just bought some Wagner Thermoquiet pads for the front and rear and Centric Premium Rotors for the front. will be using compcrasher86's write-up for the install. i'll let you know if i have trouble...this will be my first time doing brakes.
Unread 05-06-2012, 06:11 AM   #28
billyzj
1994 ZJ
brakes are easy,nice start for your thread
billyzj is offline   Reply With Quote Quick reply to this message
Unread 05-09-2012, 04:52 PM   #29
4x4Jeep
what i got today
Unread 05-09-2012, 05:36 PM   #30
peytonimor7
Oooooh where the lights going? Custom mount on front bumper?
