4x4Jeep's build thread.. - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 4x4Jeep's build thread..
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 07-20-2013, 08:32 AM   #271
thejeep88
How much did you need to shorten you drive shaft? Nice build by the way. I have a 44a with vari-lock that ill be swapping soon also.
1999 xj 4.5" and 33s
http://www.jeepforum.com/forum/f22/99-xj-build-3039617/
thejeep88 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 01:46 PM   #272
4x4Jeep
thanks. shortened mine 1/2" and then balanced it.
Build - http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031 - SOLD
4x4Jeep is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 06:28 PM   #273
thejeep88
Have any pics of it?
Unread 07-20-2013, 07:20 PM   #274
4x4Jeep
no, it doesn't look much different. i can get some tomorrow though.
Unread 07-28-2013, 11:14 AM   #275
4x4Jeep
sorry forgot about this. right now everything is covered in mud.
this past friday night i tagged along with Mid Florida Jeep Club for a night ride. there were maybe 30 jeeps, me being the only non wrangler there. got stuck in some mud and on a log.
next day a was solo riding, ran into 2 bears on the trail
also realized my stabilzer was bent...must of happened previous night.
i was waiting for a buddy to meet me out there but decided to hit this hole while waiting around. ended up being much worse than it looked. mud was really soupy except for the center part. bottomed out...all 4 tire where off the ground and my front axle buried.
you can barely see my cross-member to the right
was using a shovel to try to dig and tried using logs and my floor mats for traction, but i was too stuck for them. had a wrangler come by tried to pull me from the front, but did not budge and broke his rope. unfortunately no hitch in the rear so front was the only option. while my buddy was on his way an f250 stopped to help, no snatching, with his truck he was able to pull me out with a few tries.
took some of the ground with me
after getting out there was a new problem....front tire was flat. there was a leak in the bead so i had to put the spare on. the spare i have is a 225/75 but it'll do until i get the other repaired if i can.
hilift tire change...this tire weighed twice what it normally is lol
the inside
Unread 07-28-2013, 05:41 PM   #276
1999wjlimited
Where did you get the light mounts on the a pillar?
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is online now   Reply With Quote Quick reply to this message
Unread 07-28-2013, 06:00 PM   #277
4x4Jeep
buddy made them
Unread 07-28-2013, 06:04 PM   #278
4x4Jeep
cleaning my brakes and replacing pads
Unread 07-30-2013, 12:38 PM   #279
thejeep88
Bet youll be buying a hitch now huh haha
Unread 07-30-2013, 03:13 PM   #280
4x4Jeep
actually have a hitch for a while now. had it installed for a little then, removed it cause a buddy was building a rear tire carrier off the hitch, but he has no time to work on it anymore. so i just asked him to remove the hitch from the tire carrier, so should be getting that back soon.
Unread 08-04-2013, 03:27 PM   #281
4x4Jeep
picked up my hitch today. still has some extra steel plating on it. i'll mount it before my next trip sometime. it's hard to get work done now cause i hate the heat.
yes i need to clean the jeep out..
Unread 08-05-2013, 05:54 PM   #282
4x4Jeep
stock WJ i parked next to today
Unread 08-05-2013, 06:01 PM   #283
4x4Jeep
picked up my tire that was repaired today and no charge! then i rotated my tires...long over due. started to work on putting the hitch on, but i need longer bolts to mount it.
Unread 08-10-2013, 09:35 PM   #284
4x4Jeep
been having steering problems...couldn't turn all the way to the left, figured it was due to my beat up steering stabilizer, wasn't sure...took it off today to see and yes that was it. now i have to hope running w/o one on a 4" lift doesn't give me DW, until i get a new one (will be the 4th one in 2 yrs)...seen others mount there's higher will try that.
Unread 09-01-2013, 05:34 PM   #285
4x4Jeep
plastidipped the badges the other day...not the best job, but from a distance they look good
