4x4Jeep's build thread.. - Page 18 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 4x4Jeep's build thread..
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 05-25-2013, 10:52 AM   #256
4x4Jeep
been getting a lot of vibes up front and most of it went away when i took the front driveshaft out. possibly need a rebuild on that. forgot i had a new u-joint on my old driveshaft, so swapped that in today and put it on the jeep, since i might go riding this weekend. changed the oil today too. and steering wheel is really loose, just had an alignment a month ago...will be going back. and jeep sways a lot..not sure the problem there.
Build - http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031 - SOLD
4x4Jeep is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 01:07 PM   #257
jeremyc653
2005 WK
It's a jeep. Do you have sway bats out or bad bushings
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline   Reply With Quote Quick reply to this message
Unread 05-28-2013, 04:17 PM   #258
4x4Jeep
front/rear connected. bushings should all be good.
Unread 05-28-2013, 04:31 PM   #259
4x4Jeep
from this past weekend.
went to Ocala Nat. Forest on sunday for a few hours, camped out, wheeled a bit more in the morning.
got hung up on my front diff. hard to tell but tire is few inches off the ground.
then on the way home hit up 5a, and met some other people from FL4x4 out there, but before that i tried to go around a deep hole and ended up getting stuck on a bunch of roots.
doesn't look like i'm stuck, but my front right tire had no traction and the left rear tire was in the air. connected here.
me stuck
the result
took 5 different ways to get him out including a swamp buggy
stock cherokee and '10 4Runner
Unread 06-03-2013, 06:47 PM   #260
4x4Jeep
was looking for one jk steel wheel to mount a spare tire to. guy i contacted said $25 for one or $50 for all 5 wheels plus a brand new tire from his JK. couldn't pass it up so i got all 5, keeping one selling the rest.
guy i work with, his family owns a shop and he got me a tcase for a good price. i think its' from an '04, 130k miles, 6 mo. warranty for $160. he's gonna help with the install at his shop. beats paying $400-$600 for a shop to do it.
after that here is my to do list:
rear axle swap
front pinion seal
front axle shaft
install exhaust
Unread 06-15-2013, 03:18 PM   #261
4x4Jeep
so this morning i put the new tcase in, it was from an '02, took us about 2-3 hours first time for all of us. only problem was the connector was a bit different so had to cut the old one off and solder the new one on. tested it out in a ditch and works like never before.
new tcase..old case..soldering...work space
Unread 06-29-2013, 01:13 PM   #262
4x4Jeep
tre's today
Unread 06-29-2013, 01:42 PM   #263
4x4Jeep
switched some of my stickers around. will be adding future mods to the drivers side rear window.
passenger side has the bottom 2 stickers..
one on the passenger side as well
probably won't add anymore to the rear...if i do it will line up with the bottom of glass.
panorama of what my driveway typically looks like
Unread 06-29-2013, 02:01 PM   #264
4x4Jeep
last saturday took the jeep out with another WJ who bought my old 2" lift, his first time out...didn't end well for him though. also met up with a stock 2wd XJ out there who was stuck there for 10+ hours. helped that guy out by jump starting his jeep, but no one had jumper cables, so...
...hey, it worked
i was in 2wd 90% of the time, i used 4low wen it got really deep because i didn't want to take chances getting stuck. had the water half way up my headlights at times.
other guy hydro-locked his 300k mile motor...
also got to ride in one of these sidexside's
and almost ran over an eastern diamondback
Unread 07-03-2013, 03:43 PM   #265
fosterjd79
What did you jump that XJ with? Wires from your lights?
fosterjd79 is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 04:09 PM   #266
4x4Jeep
speaker wire he had in his jeep. he was stranded there since 3am, i found him walking down one of the trails looking for help
Unread 07-03-2013, 04:15 PM   #267
fosterjd79
Nice! Whatever works!
Unread 07-06-2013, 02:51 PM   #268
4x4Jeep
July 4th went for an easy ride in Ocala NF. found a few nice trails i have never been on.
this one had to turn around, did not have an axe or chainsaw...
this area looked nice to play in but was gated off
all of a sudden on basically flat trail i hear and feel like something in the rear is about to fall off. my whole rear axle twisted backwards cause the a-arm ball joint came out.
the angle on my springs
i ended up wrapping my tow strap and a small ratchet around the a-arm and axle and limping out of there.
drove over 3 miles of small sandy trails (a little off-camber too), that involved me, stopping and hiking up ahead to scout the trails to find the best route out of there. was trying to keep it as flat as possible. i also put it in 4low the whole way so it would be easier on the rear. once i got to the hard dirt forest roads it was about a mile drive to the nearest paved road (driving 6mph) where i met a tow truck.
jeep is currently sitting at a friends house where i am storing my 44a varilok. i ordered a ball joint from rockauto, once that comes in then its time to swap axles.
Unread 07-12-2013, 08:35 PM   #269
4x4Jeep
got the ball joint i needed on thursday and did the swap today. it is not finished i still need to get the drive shaft shortened, but the 44a is in.
d35 out
44a varilok in
took a little longer cause we got rained out and needed to stop at a shop to press the ball joint.
Unread 07-19-2013, 05:47 PM   #270
4x4Jeep
got my drive shaft back this week plus 2 new u-joints on it. bled the brakes today and finally drove her. runs good, now just need to test this vari-lok out.
