4x4Jeep's build thread.. - Page 5 - JeepForum.com
post #61 of 378 Old 06-29-2012, 09:07 AM
mrJ
2002 KJ Liberty
Are you trail-ready yet?
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #62 of 378 Old 06-29-2012, 10:32 AM Thread Starter
4x4Jeep
yea, going to citrus on july 4th
Build -
SOLD
4x4Jeep is offline
post #63 of 378 Old 06-29-2012, 11:10 AM
mrJ
2002 KJ Liberty
Who else is going
mrJ is offline
post #64 of 378 Old 06-29-2012, 11:24 AM Thread Starter
4x4Jeep
billy and brian are camping, not sure of anyone else.
Build -
SOLD
4x4Jeep is offline
post #65 of 378 Old 06-30-2012, 07:17 AM Thread Starter
4x4Jeep
just got my a/t's mounted. rides a lot smoother and looks more like a jeep now. i'll get better pictures later, as i'm going to hit some trails today.
Build -
SOLD
4x4Jeep is offline
post #66 of 378 Old 06-30-2012, 07:25 AM
mrJ
2002 KJ Liberty
Thanks for the invite
mrJ is offline
post #67 of 378 Old 06-30-2012, 09:22 AM Thread Starter
4x4Jeep
aren't you going to a truck pull or something.
Build -
SOLD
4x4Jeep is offline
post #68 of 378 Old 07-01-2012, 04:41 PM Thread Starter
4x4Jeep
some from my trip yesterday. the a/t's did noticeable better off road (as expected), did pack a lot of mud in it's treads though.
good spot to take a break
i do have some new problems with the jeep, but none that'll prevent me from daily driving. somethings up with my transfer case..it will grind and clatter..happens only sometimes, but it still works for now. also i experienced my 1st death wobble, at least i believe i did. was doing about 55-60 on the highway, all of a sudden the whole jeep was violently shaking and making noise until i came to a complete stop...does that sound like dw? i looked underneath and everything looked fine. also hasn't done it again. there was a whistling noise in the engine bay, but checked it this morning and it wasn't there. also have 30 days to get a tail light, got a ticket for that.
Build -
SOLD
4x4Jeep is offline
post #69 of 378 Old 07-01-2012, 04:52 PM
snobrdrkid07
snobrdrkid07's Avatar
If you had some mud in your rims, could be throwing it out of balance at highway speed. That would cause DW feeling.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #70 of 378 Old 07-01-2012, 06:11 PM Thread Starter
4x4Jeep
no way...i didn't go through the thick stuff the other day, and my wheels were pretty much mud free before i went. could bigger tires cause dw? same day i had put bigger tires on it.
Build -
SOLD
4x4Jeep is offline
post #71 of 378 Old 07-01-2012, 11:11 PM
Sohcvtec1995
Off balance tires could. But more then likely something is lose or worn in the suspension.
The tc noise could e from low fluid or even old fluid. When was it changed?
The noise under the hood is a good question.
Try swapping your reverse light socket with your running/brake light socket.
Sohcvtec1995 is offline
post #72 of 378 Old 07-02-2012, 11:15 AM Thread Starter
4x4Jeep
Off balance tires could. But more then likely something is lose or worn in the suspension. i don't even know if Jeremy balanced them..
The tc noise could e from low fluid or even old fluid. When was it changed? i haven't since i owned it. i'll check that.
The noise under the hood is a good question. it was one of those things that came on after a hard day of wheeling, but haven't heard anything since.
Try swapping your reverse light socket with your running/brake light socket. i've done this before, just need to pick up a pair from the jy.
got dw today doing only 35
Build -
SOLD
4x4Jeep is offline
post #73 of 378 Old 07-02-2012, 01:37 PM
Sohcvtec1995
Check your wheels an make sure they are clean. If not then a tie rod is probably bad.
post #74 of 378 Old 07-03-2012, 04:10 PM Thread Starter
4x4Jeep
today i picked up an oem hitch for $50 and had my death wobble checked out. i need to change the driver's side inner tie rod ends, but prob will change all 4, and then an alignment. hopefully that'll fix everything.
Build -
SOLD
4x4Jeep is offline
post #75 of 378 Old 07-03-2012, 04:26 PM
PhantomWJ
2003 WJ
New TRE's will make your steering as tight as a *****cats bunghole...
PhantomWJ is offline
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
