4x4Jeep's build thread.. - Page 3 - JeepForum.com
post #31 of 378 Old 05-09-2012, 05:02 PM Thread Starter
4x4Jeep
wanted to see how they looked. i haven't wired them yet, i want to wire them to the factory fog light switch. i won't get around to this until after i put my pads/rotors on.
Build -
SOLD
4x4Jeep is offline
post #32 of 378 Old 05-21-2012, 11:43 AM
Sohcvtec1995
let me know if you need any help im always down to work on a jeep.
Sohcvtec1995 is offline
post #33 of 378 Old 05-21-2012, 05:50 PM
peytonimor7
^^I second that, if you need help working on it and can still drive it to Prosperity here in SC, I'll share some beer and cigs with you
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #34 of 378 Old 05-22-2012, 10:31 AM Thread Starter
4x4Jeep
when i do the lights i will need help, but i want to fix the radiator before the lights.
if i ever break down in SC i'll make sure i look you up.
Build -
SOLD
4x4Jeep is offline
post #35 of 378 Old 05-22-2012, 10:52 AM
Sohcvtec1995
whats wrong with it? bring it by and we can get it all done up for you
post #36 of 378 Old 05-22-2012, 11:08 AM Thread Starter
4x4Jeep
my brakes were completely shot, couldn't drive the Jeep anywhere, i did contact Kolak to see his prices, but they were more than i wanted to spend at the moment, so i went to rockauto.com and picked up Wagner Thermo pads (f/r), front Centric rotors and a new radiator cap for $173 shipped.
this was my first time doing pads and rotors. i followed a write-up on here which helped a lot. once i did one side, the other was a lot easier.
old rotor and pads
the rotor was really stuck even after beating on it with a mini sledge, so i came on JF to see if anyone else had that problem, and it seems pretty common. i read to just keep on beating on it and it WILL come loose. that's what motivated me and after of about 20 minutes more it finally came loose.
everything off
new rotor
pads
once i did the other side (passenger) i ran into a problem. one of the caliper bracket pins wouldn't come out. i tried lubing it up, i used pb blaster, i beat it with a sledge...never budged. i was limited on time, so i decided to buy a new bracket and sliding pins since they were cheap at autozone. they had the caliper bracket in stock but not the pins and rubber boots. i checked 2 more AZ's and 2 advance auto parts and no one had them. so i had to bolt everything back up and the jeep sat for about a week until my pins and rubber boots came in.
pic of the old bracket w/ stuck pin
reman. bracket from AZ
all ready for a test drive
i've read that people get squealing, smoke and smells during their break-in period, but all i had was a whining noise the first 10 miles. drove it to work today for the first time with the brakes and they seem fine. and i'm happy i driving it a lot.
next thing i will be doing is get my overheating problem fixed. i'm going to be taking it to a radiator shop that uses some chemical they dip the radiator in to really clean it. friend recommended it. if that doesn't work i'll have to get a new or used radiator. also had a slow tire leak when the wj was sitting, right now the tire is at discount tire, and i have a 245/70 spare i picked up, on it now.
Build -
SOLD
4x4Jeep is offline
post #37 of 378 Old 06-01-2012, 10:51 AM Thread Starter
4x4Jeep
took some pics today in the rain
looks funny w/o the grille
Build -
SOLD
4x4Jeep is offline
post #38 of 378 Old 06-03-2012, 07:10 AM
mrJ
2002 KJ Liberty
lookin good
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #39 of 378 Old 06-03-2012, 01:11 PM Thread Starter
4x4Jeep
thanks...getting closer to buying tires and that lift if billy still has it.
Build -
SOLD
4x4Jeep is offline
post #40 of 378 Old 06-03-2012, 07:25 PM
JulietheJeep
Looks good, I'm on tranny #2 after loosing my reverse, need to replace my transmission pan gasket, was slipping so i checked my fluid and the stick was completely dry
If your slide pins stick grab a pair of vice grips and just twist em till they come out then lube them up real nice, whenever I change my brakes I re-lube the slide pins because they stick so often.
Nice Jeep though looks good I have 3" IRO lift and 31" rugged trails I love it!
Steel Blue WJ named Julie.- R.I.P. Julie the Jeep
Another Steel Blue WJ named Jenn.
3" IRO Lift, Bilstein 5100s, 32s, Roof basket
JulietheJeep is offline
post #41 of 378 Old 06-03-2012, 07:57 PM Thread Starter
4x4Jeep
i beat the hell out of that one slide pin and it wouldn't budge. so i just bought new parts since they were cheap.
Build -
SOLD
4x4Jeep is offline
post #42 of 378 Old 06-04-2012, 10:20 AM
billyzj
1994 ZJ
wheres your grill at mike
billyzj is offline
post #43 of 378 Old 06-04-2012, 08:10 PM Thread Starter
4x4Jeep
i still have the grille, just never put it back on from when i cleaned the radiator off. still have the springs?
Build -
SOLD
4x4Jeep is offline
post #44 of 378 Old 06-04-2012, 08:39 PM
mrJ
2002 KJ Liberty
Which springs you talking about? My old ones? Better look at an IRO 3" kit mikey, he sold those a long time ago
mrJ is offline
post #45 of 378 Old 06-05-2012, 04:49 AM
billyzj
1994 ZJ
yeah there gone
billyzj is offline
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
