2004 WJ Freedom Edition into DevilDog Edition - Page 5 - JeepForum.com
post #61 of 267 Old 02-20-2012, 12:58 PM Thread Starter
USMCBehrensDVLD
did the gauges today, i like the way they look now so much better. and got my amber strobes all hooked up too.
USMCBehrensDVLD is offline
post #62 of 267 Old 03-19-2012, 08:17 PM Thread Starter
USMCBehrensDVLD
Washed her finally and put some new lights in the marker lamps, like the color but was hoping they'd be a little brighter, ill keep looking. and took off the bug deflector but revealed some paint rub off and marks underneath.
And plan on doing the "Removal of the air box noise reducer" this weekend and will do a write up in separate thread since people asked to.
post #63 of 267 Old 03-22-2012, 11:24 AM
Dluenz
awesome WJ!
Dluenz is offline
post #64 of 267 Old 03-23-2012, 07:56 PM Thread Starter
USMCBehrensDVLD
Originally Posted by Dluenz View Post
awesome WJ!
Thanks
post #65 of 267 Old 03-23-2012, 08:00 PM Thread Starter
USMCBehrensDVLD
finally took her wheeling again today, although found out today need some spacers on her, the tires rub the struts when i flex for the rear and should probably invest in a locker for at least the rear.
And gonna try and do the removal of the air box noise reducer for the 4.0 tomorrow, will do a write up too.
post #66 of 267 Old 03-23-2012, 11:42 PM
Dasko
your ride looks awesome man! Keep up the work
2005 Grand Cherokee Limited - 5.7 HEMI - QDII - 2" Rough Country BB - AFE Stage 2 CAI - Monkey Navigated - Rear Shackle
2001 WJ- SOLD
Originally Posted by mrJ
It's a Jeep, it's not supposed to work right all the time.
Dasko is offline
post #67 of 267 Old 03-28-2012, 02:22 PM Thread Starter
USMCBehrensDVLD
Thanks and will defiantly have more to come
post #68 of 267 Old 03-28-2012, 02:31 PM Thread Starter
USMCBehrensDVLD
I am not doing the Removal of the Noise Dampener above the TB because as i was tryinig to do it i noticed its more work than its worth especialy with how the stock air box has a oval outlet.
Although after my last off road adventure when i hosed her down and got her clean i noticed one of the Freedom Edition "rock sliders" was pinched against my body. Didn't take long to realize it was from off roading. So now im pondering the idea to get real rock sliders in place of the freedoms and painting them silver. But im not sure it will look as good or normal with them silver and i am still trying to maintain the freedom edition look.
Looking for some input
post #69 of 267 Old 03-29-2012, 10:17 PM Thread Starter
USMCBehrensDVLD
bought spacers (10MM), took off the freedom edition sliders to sell for real sliders, and throttle body spacer
post #70 of 267 Old 03-30-2012, 07:10 AM
silentbob21
Seems you are off to a good start, love the black WJs.
I would guess that you are in the reserves ? Have a friend that is in NY reserves as well...
keep it coming, addiction never seems to let up.
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #71 of 267 Old 03-30-2012, 03:15 PM Thread Starter
USMCBehrensDVLD
Yeah you guessed right, and thanks more to come for sure
post #72 of 267 Old 03-31-2012, 07:39 PM Thread Starter
USMCBehrensDVLD
yesterday night was driving when the caliper for my front drivers side brakes broke off the braket and thus tearing our the ABS sensor and made a nice score in the inside of the rim.
Today found out its going to cost $420.00 to fix seems like i fix one thing enjoy it for a week and another thing breaks.... must be a jeep thing.
post #73 of 267 Old 04-03-2012, 08:16 PM Thread Starter
USMCBehrensDVLD
got my truck back this afternoon, decided to put my 10MM spacers on and saw the damage of the struts from the tires. Rubbed of the paint to the metal every time i flexed.
post #74 of 267 Old 04-03-2012, 08:51 PM
TX-WJ
TX-WJ's Avatar
Not trying to knock your thread, but you may want to invest on some longer wheel-studs to account for the thickness of the spacers if your going to run that type of spacer on the freeway; there will be significantly less thread engagement if you run those with the the stock studs and it could become a safety issue at some point. Or run spacers with built-in studs like spidertrax and the like.
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline
post #75 of 267 Old 04-03-2012, 10:55 PM Thread Starter
USMCBehrensDVLD
No your not knocking it but thanks i had thought of that originally but i took the caps off a couple of the lugs and you can see how much thread it catches and there's still a little past so technically has the same amount of thread grab as before.
2004 grand cherokee freedom edition question aztec12 Grand Cherokee General Discussion 1 08-11-2010 03:00 PM
New Jeep Owner - 2004 GC Freedom Edition JeepPimp Grand Cherokee General Discussion 35 03-10-2010 07:22 PM
04 freedom edition eagans2002 ZJ Grand Cherokee Forum 2 10-20-2009 06:22 PM
Lift my 2004 GC Freedom Edition? bearlax4 ZJ Grand Cherokee Forum 55 05-23-2006 10:51 PM
Lift kit for 2004 Freedom Edition GC? MGNiko ZJ Grand Cherokee Forum 10 11-05-2004 12:20 PM
