2004 Grand Laredo build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 2004 Grand Laredo build
Ruffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-09-2014, 05:54 PM   #1
Major-Cherokee
I've got a lot of ideas running through my head about how to build my car and I've done a lot with it already. So I figured I'd show off what I've done and what I plan to do to everybody and get ideas from people to further my build and guide people with what they plan to do.
Major-Cherokee is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 10:07 PM   #2
Major-Cherokee
My current project is restoring these overland rock rails I bought. I put on a couple coats of rust preventative and the next step is to primer then paint and clear coat for the best results. I've got to order the u-clips that go in the frame from online but they are cheap. After this winter I'm going to check on them and continue to restore them through the seasons as I need to.
Unread 11-09-2014, 10:12 PM   #3
Major-Cherokee
One of my last projects was painting my roof racks silver. I kinda did a sloppy job since it was my first time really painting car parts but they look good now. In the near future I'm going to go over them again to make them look even better.
Unread 11-10-2014, 05:13 PM   #4
Major-Cherokee
[QUOTE="Major-Cherokee"]I've got a lot of ideas running through my head about how to build my car and I've done a lot with it already. So I figured I'd show off what I've done and what I plan to do. My goal is to help anybody that I can, and to get ideas from people to further my build
Unread 11-11-2014, 11:15 PM   #5
MoonyJohn
Mountain Climber
MoonyJohn's Avatar
I was thinking of painting mine too, what color did you end up using? Prep work?
Good luck with the build!
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 11-13-2014, 10:52 AM   #6
Major-Cherokee
I decided to try doing the same silver as my roof racks and painting the end caps black. If I decided I don't like how it looks i'll probably paint them gray.
Unread 11-13-2014, 11:48 AM   #7
Major-Cherokee
Preva work wise I sanded all the rust off, cleaned them up, went over with primer and rust preventative, finished, and then clear coated. I wanted maximum protection and to look great for a long time. If I have to next spring I'm going to everything depending on how the winter treats them.
Unread 11-19-2014, 02:05 PM   #8
Major-Cherokee
The silver turned out great!
Unread 11-19-2014, 02:06 PM   #9
Major-Cherokee
The black caps look great too!
Unread 11-19-2014, 02:07 PM   #10
Major-Cherokee
Unread 11-22-2014, 03:50 PM   #11
Major-Cherokee
The rails are on now!
Unread 11-22-2014, 11:21 PM   #12
Major-Cherokee
I've started on the process of painting my front bumper.
Unread 12-02-2014, 08:54 PM   #13
Major-Cherokee
A huge relief for me! I finally rigged up the fog light housings that I had! I can finally see better at night and use the harness I made myself
Unread 12-02-2014, 09:05 PM   #14
eastcoastcam
Originally Posted by Major-Cherokee View Post
I've got a lot of ideas running through my head about how to build my car and...
You could start by not calling it a car. It is a JEEP
Really nice job on the rock rails. They look sharp
eastcoastcam is offline   Reply With Quote Quick reply to this message
