2002 Jeep Grand Cherokee Stalling Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 2002 Jeep Grand Cherokee Stalling Help
Trick Tabs - NalinMFG.comCCOR is your 1 stop source for everything Jeep!TJ 5.25" Speaker Adapters - NalinMFG
Unread 07-06-2014, 04:49 PM   #1
deb123
Dear Jeep Forum,
I need help. My Jeep has been stalling at random times for about 7 months now. It's gotten progressively worse. Since late December I've had the crankshaft position sensor, the engine oil pressure regulator, and an engine fan replaced all trying to fix the stalling issue. After each repair the car will seem "fixed" but within a few weeks (this last time it was 2 weeks) it will start stalling again. Today I was only able to drive 6 miles before it conked out and then sat there for about 40 minutes before the car would turn back on. Yesterday it was 35 minutes before it came back on. Part of the problem is that when I bring it to the mechanic, he can't replicate the stalling so he gives it back to me and then it stalls on me.
Recently it stalled near an Advance Auto Parts and they were able to do some tests on it. The check engine light provided no codes, and then the car was able to start and they checked the battery. It was a little low but nothing too bad, but the alternator was lower than it should be.
I took a picture of my dashboard today when it stalled with the intention of writing this post.
https://www.dropbox.com/sc/h1kagvxtl...c4reLCJgel2aha (just in case it doesn't show up as an image)
Any ideas of what could be wrong? Thank you!!!!!
-Deb
deb123 is offline   Reply With Quote
