2001 on 37s - Building it up - Page 9 - JeepForum.com
post #121 of 845 Old 04-21-2013, 09:20 AM Thread Starter
dillonjm
2013 WK
Originally Posted by jessebrown View Post
I wish knew how to do all that axle work. Awesome job, can't wait to see if finished!
Never too late to teach yourself. I'm far from an expert.
This is a good place to start:
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #122 of 845 Old 04-21-2013, 09:37 AM
SDHarleydad
1994 ZJ
subsbd
Casper
1994 JGC Laredo
SDHarleydad is offline
post #123 of 845 Old 04-21-2013, 01:52 PM Thread Starter
dillonjm
2013 WK
Not horrible.. First is drive side, second is coast
Calling it quits for the day, wife is going out of town for a week, going to do dinner and a movie.
dillonjm is offline
post #124 of 845 Old 04-21-2013, 09:40 PM
TJSWJ
Originally Posted by dillonjm View Post
Spent most of the day in KC, but when I got home I started working on the front gears. Got the old gears apart, setup bearings made, shims measured, and ring gear on the OX.
Then I got hungry.
Any more info on how you made your own setup bearings. I found it mentioned in the pirate thread you linked, but couldnt find any more info on it.
TJSWJ is offline
post #125 of 845 Old 04-21-2013, 10:07 PM Thread Starter
dillonjm
2013 WK
Sure, I took the old bearings I pressed off and used my dremmel to hone out the ID of the bearing so that it was a hand fit onto the carrier and pinion. I ground them out just enough that I could push them on by hand but not so much that they were loose.
Makes it so you don't have to press the bearings each time you change shims. Then after I got the pattern where I wanted I pressed on the new bearings and put it all back together.
Hope that was clear enough.
dillonjm is offline
post #126 of 845 Old 04-21-2013, 10:12 PM
TJSWJ
Plenty clear. I figured it was something to that effect, the fact that its really that easy is what threw me off. Thanks!
TJSWJ is offline
post #127 of 845 Old 04-24-2013, 05:43 PM Thread Starter
dillonjm
2013 WK
Had to run a jet to Tucson yesterday hence the lack of work.
Burned on the base brackets for the coils. Gotta cut off the track bar mount deal on the passenger side as I'm using Claytons TB bracket for high steer. These brackets were originally T&T's TJ brackets I moved wider for the WJ. Also have to weld on the center cup(not sure what you'd call it) for the isolators to sit on.
I'm kinda taking parts I like from different places and welding them to the truss I liked.
As soon as I have the front as far as I can go until more parts get here I'll cut off the rears brackets and leaf spring mounts and get the gears in it. I **expect** to have that done NLT this weekend.
Oh, and the shafts, knuckles, etc are staying off until I get it under the jeep. Its heavy enough as it sits..
dillonjm is offline
post #128 of 845 Old 04-24-2013, 05:58 PM Thread Starter
dillonjm
2013 WK
Also, Mike from Protofab emailed and said they loaded my bumpers and got them on the road yesterday.
Looking forward to getting those mounted up.
dillonjm is offline
post #129 of 845 Old 04-24-2013, 06:58 PM Thread Starter
dillonjm
2013 WK
And where I stop for the night.
Cups burned on and bracket cut as needed. And yes, I intentionally put them centered on the axle instead of offset forward.
dillonjm is offline
post #130 of 845 Old 04-24-2013, 08:20 PM
wvracer821
wvracer821's Avatar
that thing is looking great. explain the reason for not offsetting the spring perch. wouldn't this create a low caster angle when springs are straight?
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #131 of 845 Old 04-24-2013, 08:28 PM Thread Starter
dillonjm
2013 WK
I took this into account when I welded the truss, I set vertical @ 5 degrees of caster.
All moving the cups directly over the axle did was push the axle forward a little under 2".
dillonjm is offline
post #132 of 845 Old 04-24-2013, 09:43 PM
badassdude
i think what you're getting at is TLAR
badassdude is offline
post #133 of 845 Old 04-25-2013, 05:23 AM Thread Starter
dillonjm
2013 WK
Standard
dillonjm is offline
post #134 of 845 Old 04-26-2013, 07:44 PM Thread Starter
dillonjm
2013 WK
Pulled the NP247 today, guy picks it up tomorrow.
Also started disassembling the 60 to get it ready.
Then I ordered a Dorman plastic tank to modify for my windshield washer bottle since I need to relocate from the stock bottle location.. I fully intended to use a ZJ setup and change my intake or move the evap system but decided to go a different route since I really don't like the open element style filters.
dillonjm is offline
post #135 of 845 Old 04-27-2013, 09:39 AM
mtnmarc
Picture or link to the plastic tank? I haven't had a washer bottle in years. Carrying around a bottle of water for the windshield gets old after a while. Hahah.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
