2001 on 37s - Building it up - Page 55 - JeepForum.com
post #811 of 846 Old 02-16-2014, 10:21 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Gonna make a new thread for the Rubi?
May TJ of the Month 2015
TexasTJ is offline
post #812 of 846 Old 02-17-2014, 03:58 PM
Geo-Nemesis
your WJ "was" (it still is) epic!
'02 Black Overland H.O. V8
Geo-Nemesis is offline
post #813 of 846 Old 02-17-2014, 06:37 PM Thread Starter
dillonjm
2013 WK
Thanks guys, I will start one here in a bit.
The Rubi really isn't getting changed much and therefore doesn't really need much of a thread. I'm just cleaning it up (flares, fixing some paint spots on the rocker guards, skids, and suspension to prevent rust, etc) a bit then wheeling it.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #814 of 846 Old 02-18-2014, 07:13 AM
CommanderWJ
Well I'm sad to see the WJ go, but congrats on the Rubi!
2001 WJ 4.7 V8 Ltd QD. 2" Rough Country BB, TF QD's, Rough Country shocks, BDS Adjustable front UCA's, RC 2.2 steering damper, 245-70R17 Firestone Destination muds/ 245-75R17 Wrangler A/T's on Moab's, Flat Land non-winch steel bumper, rear sway bar removed, Power Brake matched disc and pad set. More to come!
CommanderWJ is offline
post #815 of 846 Old 02-18-2014, 07:24 AM
caronaxtr
X2, would love a Rubi, but that WJ, That was awesome. Who'd you sell it to? Hopefully someone on here so we can still follow it's progress.
caronaxtr is offline
post #816 of 846 Old 02-18-2014, 07:25 AM
ChrisHager
Administrator
ChrisHager's Avatar
Sharp Rubi!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #817 of 846 Old 03-27-2014, 12:47 AM
Russell84
2003 WJ
Sad to see the WJ go, but I'm still going to use this thread to help with my build. Parts ordering will start very soon and I'm now looking for a 14b rear instead of a 60 since they're so much easier to find and cheaper to boot. Everything else will be modeled closely off of your build to hopefully minimize the amount of headaches and downtime with my build. Congrats on the Rubi!
-Rusty
2003 WJ Overland 4.7 HO, Clayton Long Arms, Teraflex 4.5" coils, JKS adj trackbar, JKS Quicker Discos, 17x9 Eagle Alloy Series 185, 285/70/17 BFG KM2, cut fenders/bumpers
Russell84 is offline
post #818 of 846 Old 11-06-2014, 08:04 AM
LSRGreg
I know you sold your wj, but did you have any driveline vibes once you had it complete? I'm talking about on the street up near 50 to 80 mph?? Me and 2 others with 6"+ of lift can't get rid of the vibes once we geared up to 4:56 and higher gears. Just curious if you had similar issues or not. Thx! Killer build btw.
04 WJ, Limited, 4.7 HO, w/ lots of goodies
Incline Winch bumper from WWW.FRANTZDESIGNWORKS.COM
LSRGreg is offline
post #819 of 846 Old 11-06-2014, 08:50 PM Thread Starter
dillonjm
2013 WK
Nope. I had some tire balancing issues but once I got those straightened out it rode smooth up through 80 which was as high as I took it. I had manual hubs which I usually had disengaged on the street but I drove it at highway speeds with them engaged too and didn't have driveline vibes then either.
Where are your vibes coming from?
dillonjm is offline
post #820 of 846 Old 11-07-2014, 09:11 AM
LSRGreg
Ok. Cool. What height of lift were you at? And diff gear ratio?
Were all getting the vibes from the front and rear driveshafts. Mine is mostly the front. The other 2 guys have swapped in jk44 front and rear with 5:13 gears. None of us had vibes until the gear change. We know the shafts are spinning faster and have had multiple shops look at them and rebuilt / balanced shafts multiple times etc. so I'm just trying to narrow down situations.
Thx for the feedback!
LSRGreg is offline
post #821 of 846 Old 11-07-2014, 09:58 AM Thread Starter
dillonjm
2013 WK
I was at 6" coils with a 3/4" spacer in the rear and the front had some 2" spacers on top to compensate for winch and bumpers' weight.
I was running Yukon 5.13s with the factory front driveshaft and a Tom Woods rear. I was also running a 231 tcase with a standard length slip yoke eliminator. I had JB conversions build one of their HD cases with the correct input for the transmission. I set the pinion angle 1 degree below straight at the transfer case output shaft.
Did you guys stick with the stock t-case and slip yoke shaft? If so that's probably where your issuse lie. I went with a 231 specifically for that reason (couldn't find a SYE for the stock tcase)
dillonjm is offline
post #822 of 846 Old 11-07-2014, 12:57 PM
LSRGreg
Yeah we are basically at the same lift as yours. We are all running 242hd t- cases. They have sye's, and I don't. One guy even swapped his 247 back in with a sye, and it didn't make a difference.
I think a little could be coming from my slip yoke, but I really only have vibes on decel for the rear and they are pretty minor. I can live with mine on the rear. Mine is more the front that gets nasty. So much that you can't see thru the rear view mirror because it's shaking so much. Haha. I have a little play on my tcase yoke and pinion yoke on my front end. I just ordered a dial indicator to measure it, and will have to research what is acceptable. I wouldn't think any play would be acceptable, so not sure. Just trying to rule out everything and get to the bottom of it.
LSRGreg is offline
post #823 of 846 Old 11-07-2014, 02:00 PM Thread Starter
dillonjm
2013 WK
Could be the cv ball joint in the front shaft. Shouldn't have play in it. That would cause some nasty vibrations if it is worn.
dillonjm is offline
post #824 of 846 Old 11-07-2014, 03:43 PM
LSRGreg
I will have to check that. Mine is original that I had extended and balanced when I lifted it. The other two guys got new shafts built I believe. Thanks again for your help!
LSRGreg is offline
post #825 of 846 Old 11-07-2014, 05:25 PM Thread Starter
dillonjm
2013 WK
No worries. Hope you guys get it sorted out.
Cheers
dillonjm is offline
