2001 on 37s - Building it up - Page 4 - JeepForum.com
post #46 of 845 Old 04-10-2013, 06:08 AM
WJFrank88
crawled.
2006|4.7|QDII|OME HD|265/70/17Grabber AT2|D-ring receiver|Magnaflow|3' Firestik|Steel Armadillo
WJFrank88 is offline
post #47 of 845 Old 04-10-2013, 06:09 AM
HaskiE
HaskiE's Avatar
sub'd!
#theneverendingaxe
HaskiE is offline
post #48 of 845 Old 04-10-2013, 06:58 AM
wvracer821
wvracer821's Avatar
this is starting to get good! keep it up
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #49 of 845 Old 04-10-2013, 10:51 AM
mtnmarc
what shocks will you be running?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #50 of 845 Old 04-10-2013, 12:52 PM Thread Starter
dillonjm
2013 WK
Bilsteins, nothing fancy.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #51 of 845 Old 04-10-2013, 02:19 PM
mtnmarc
What travel?
mtnmarc is offline
post #52 of 845 Old 04-10-2013, 02:25 PM Thread Starter
dillonjm
2013 WK
What travel?
Just the standard ones Clayton pairs with their 6" coils. I think they are 11.5" of travel.
I didn't get to on far out in the weeds with the suspension, its pretty vanilla.
Maybe someday I'll get some coilovers but I had to draw the line somewhere. This is already getting close to ridiculous.
dillonjm is offline
post #53 of 845 Old 04-10-2013, 03:43 PM Thread Starter
dillonjm
2013 WK
Patched in some new metal and sealed up the seams.
dillonjm is offline
post #54 of 845 Old 04-10-2013, 07:22 PM Thread Starter
dillonjm
2013 WK
Got the driver side to the same point, same process but much quicker the second time through:
Giving the sealer time to cure, then gonna sand and hit with some paint.
Probably at a stopping point for the night. I'd planned on pull in my axles in but its been storming all day and I'll wait till it clears up some.
On a side note, the gears got here today. My welding blanket should be here Friday, gotta keep from melting the new flooring...
And for a little axle teaser, here's my front truss:
dillonjm is offline
post #55 of 845 Old 04-10-2013, 07:44 PM
thejeep88
Good call on the gears build is looking great so far man.
1999 xj 4.5" and 33s
http://www.jeepforum.com/forum/f22/99-xj-build-3039617/
thejeep88 is offline
post #56 of 845 Old 04-10-2013, 07:55 PM Thread Starter
dillonjm
2013 WK
Thanks.
After doing the rear cuts I'm surprised someone isn't running 31-32s on a stock suspension with just trimming. It opens up the wheel well quite a bit.
dillonjm is offline
post #57 of 845 Old 04-11-2013, 02:10 AM
mtnmarc
Originally Posted by dillonjm View Post
Thanks.
Everyone with stock suspension is too scared to cut. Hahah.
mtnmarc is offline
post #58 of 845 Old 04-11-2013, 07:11 AM
ChrisHager
Administrator
ChrisHager's Avatar
Those are some clean saw horses. I bet you can't wait to get some grime and paint on them!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #59 of 845 Old 04-11-2013, 10:49 AM
VA-WJ
If the rust on my back and front fenders gets much worse, you will see me cutting with stock suspension! Might as well since rust is helping me make the decision. Just at a loss on how to reuse the factory plastic bumpers I will have to trim after I remove their main connection points from the bumper and the Jeep.
VA-WJ is offline
post #60 of 845 Old 04-11-2013, 06:01 PM Thread Starter
dillonjm
2013 WK
Front passenger trimmed and rolled:
dillonjm is offline
