2001 on 37s - Building it up - Page 37 - JeepForum.com
post #541 of 845 Old 06-30-2013, 08:43 PM Thread Starter
dillonjm
2013 WK
And the other side.
I ended up partially welding them for a little added support.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #542 of 845 Old 06-30-2013, 08:44 PM Thread Starter
dillonjm
2013 WK
I'm going to move the axle forward another 1/2" to an 1" to help clear the back of the fender wells at full turn and flex. Gotta clearance the differential a little bit at the bracket and then I'll be able to use the next set of holes on my brackets.
My limiting straps are in the mail too, I'll mount those up before the first trip out this week. Going with straps on the corners, the rears I'm going to mount to the shock bolts, the fronts I'm going to make a bracket. 24" in the front with how I'm going to mount the bracket and 27" in the rear.
dillonjm is offline
post #543 of 845 Old 06-30-2013, 08:59 PM
CRJEeP_wj
Looks good. How far forward will your axle be from stock? I couldn't go much further with mine cause of the steering. Even with a steeper pitman arm.
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
post #544 of 845 Old 06-30-2013, 09:24 PM Thread Starter
dillonjm
2013 WK
Not sure. I can always move the drag link to the aft hole of the high steer arm if I need to. I think it can go forward a little more and be OK.
dillonjm is offline
post #545 of 845 Old 06-30-2013, 10:41 PM
silentbob21
I'm curious about the limiting straps... Will they stop the flex before the springs unseat? Or are you limiting it so that you don't have to worry about retainers?
I'm also curious if you did anything with the ebrake cables, when I first started flexing the rear my cables would be holding the axel up, now it's the rear sway bar if its attached
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #546 of 845 Old 06-30-2013, 10:52 PM Thread Starter
dillonjm
2013 WK
I'm using the limiting straps to limit down travel just prior to the coil unseating/shock fully extending. You don't want your shocks to be what limits travel, it causes premature wear and if the coil unseats you have no weight on that tire anyway so its doing you no good, the locker is pushing you at that point on one tire.
I'm running lower coil retainers on all 4 corners in the form of a circular plate that is bolted to the axle.
As far as ebrake cables they aren't hooked up at the moment because I'm still trying to source the caddy ebrake hardware for the El Dorado calipers I have in the rear. So far its either junkyard hopping or ordering 300+ dollar calipers that come with new hardware.
dillonjm is offline
post #547 of 845 Old 06-30-2013, 11:10 PM Thread Starter
dillonjm
2013 WK
Sliders are the best mod for dubs. I banged mine up pretty good and i had 35's and 6.5" lift too.
Looks good as always
Yeah, the rocker clearance isn't great even with 37's and 7" of suspension.
My YJ on 35s may have had more clearance at the tcase skid that I have at my rockers now.
dillonjm is offline
post #548 of 845 Old 07-01-2013, 09:22 AM
oaklyjeep10
[QUOTE=silentbob21;15626715]I'm curious about the limiting straps... Will they stop the flex before the springs unseat? Or are you limiting it so that you don't have to worry about retainers?
I'm also curious if you did anything with the ebrake cables, when I first started flexing the rear my cables would be holding the axle up, now it's the rear sway bar if its attached[/QUOTE
I was going to ask the same question.
How did you measure for the straps? Just drop the suspension down till the springs are loose then up a little?
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #549 of 845 Old 07-01-2013, 11:24 AM Thread Starter
dillonjm
2013 WK
[quote=oaklyjeep10;15627667]
Yep, pretty much how I did it.
dillonjm is offline
post #550 of 845 Old 07-02-2013, 09:23 AM
TJSWJ
Ruffstuff is having a 4th of July sale if your still looking for limit straps. 18% off using code 1776
TJSWJ is offline
post #551 of 845 Old 07-02-2013, 10:32 AM
oaklyjeep10
Originally Posted by tjswj View Post
ruffstuff is having a 4th of july sale if your still looking for limit straps. 18% off using code 1776
gracias
post #552 of 845 Old 07-03-2013, 02:38 PM
65novalt1ss
Do you have any pictures of how those sliders are mounted? I am wanting to build some but have not seen any way to mount them that i am crazy about. Is the main tube 2x3? This is a great looking jeep. It makes me want one this color. Keep up the good work.
65novalt1ss is offline
post #553 of 845 Old 07-03-2013, 05:42 PM Thread Starter
dillonjm
2013 WK
Here you go:
They base piece is 2x4 rectangular tubing.
dillonjm is offline
post #554 of 845 Old 07-03-2013, 05:46 PM Thread Starter
dillonjm
2013 WK
Got the diff clearanced inside of my LCA bracket on the driver side and got the arms up into the next highest hole, moved the axle forward about 1/2-3/4".
I believe this should keep the tires out of the inner fenders under flex with the wheels turned, we will find out this weekend.
Also got the rear limiting straps mounted up, will do the fronts tomorrow or Friday.
dillonjm is offline
post #555 of 845 Old 07-04-2013, 12:27 AM
CommanderWJ
Can't wait for those first trail pics!
2001 WJ 4.7 V8 Ltd QD. 2" Rough Country BB, TF QD's, Rough Country shocks, BDS Adjustable front UCA's, RC 2.2 steering damper, 245-70R17 Firestone Destination muds/ 245-75R17 Wrangler A/T's on Moab's, Flat Land non-winch steel bumper, rear sway bar removed, Power Brake matched disc and pad set. More to come!
CommanderWJ is offline
