2001 on 37s - Building it up - Page 36 - JeepForum.com
post #526 of 845 Old 06-26-2013, 02:43 PM
tucsonzj
Originally Posted by dillonjm View Post
Thought about building upper coil retainers today. Its too damn hot.
I did replace the tapered rear upper shock bolts with some normal shafted bolts today. Quieted up the rear suspension considerably.
And took a pic of the Jeeps next to each other:
Shakedown run is gonna be the 6th. Planning on hitting up Tuttle Creek since it has plenty of easy stuff I can check my clearances and travel on.
For the record I miss AZ wheeling. Old video of me letting a buddy try out my YJ:
https://picasaweb.google.com/1110811...30221746400162
The idiot laughing like a hyena would be me.
aww reddington pass. I miss it too my friend.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #527 of 845 Old 06-26-2013, 03:41 PM
CRJEeP_wj
Thats a nice yj! That line looked fun, he definitely had some pucker moments. Now I wanna see a wj do that line, im interested to see if the longer wheel base would keep all 4s on the ground or at least closer.
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
post #528 of 845 Old 06-26-2013, 05:18 PM Thread Starter
dillonjm
2013 WK
Good question.
I never was able to run over that side of the climb and not lift a tire at least once.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is online now
post #529 of 845 Old 06-26-2013, 05:36 PM Thread Starter
dillonjm
2013 WK
Got my butt in the garage this evening. Mounted up my lower front coil retainers, and am playing around with spacers. I think I'm going to run 3/4"ers...maybe.
Also, measuring for limiting straps. Looks like roughly 22" in the rear should work. Depending on where I mount it I could run anything from ~20-26". Gonna measure the front after dinner.
post #530 of 845 Old 06-26-2013, 11:52 PM
macbethpoe1
Please if possible, take some video on your first run!
macbethpoe1 is offline
post #531 of 845 Old 06-27-2013, 08:47 AM
ChrisHager
Administrator
ChrisHager's Avatar
http://www.lowes.com/pd_408056-85334...3736193&rpp=32
Just a water based duct sealer. Flexible, sandable, paintable. Takes a day or two to cure depending on how thick you go.
No kidding? I never thought about using that stuff. Then again, it makes sense! I've had my hands dipped in that goop more than once. Fun to play with. Horrible to remove from arm hair once it's dry.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #532 of 845 Old 06-27-2013, 10:18 AM
wj4play
Just use regular auto body caulking like they do atthefactory - any auto parts store with have some
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #533 of 845 Old 06-29-2013, 11:07 PM Thread Starter
dillonjm
2013 WK
Spent some more time driving today.
Cruising down the highway this evening @70 a guy cut me off going about 30. Cars on both sides and no where to go, almost got to test the new bumpers.. For the record the brakes lock up great. Was able to get slowed, but not by much. Thankfully the couple cars behind me's brakes worked also...
Gonna pull the covers and check the gears this week, I've almost got 500 miles on them.
Sliders got in today as well.
post #534 of 845 Old 06-30-2013, 09:37 AM Thread Starter
dillonjm
2013 WK
Painting the sliders:
post #535 of 845 Old 06-30-2013, 09:50 AM
silentbob21
Which sliders are those ?
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #536 of 845 Old 06-30-2013, 10:02 AM Thread Starter
dillonjm
2013 WK
Kevin's Offroad
post #537 of 845 Old 06-30-2013, 12:34 PM
Russell84
2003 WJ
Wow, dude. Your dub is growing fast! I'm still waiting for my bumper to get here. Protofab is apparently really backed up. I'm interested to see how you like the way those sliders mount up.
-Rusty
2003 WJ Overland 4.7 HO, Clayton Long Arms, Teraflex 4.5" coils, JKS adj trackbar, JKS Quicker Discos, 17x9 Eagle Alloy Series 185, 285/70/17 BFG KM2, cut fenders/bumpers
Russell84 is offline
post #538 of 845 Old 06-30-2013, 03:23 PM Thread Starter
dillonjm
2013 WK
Yeah, mine took almost 6 weeks, so don't feel too bad.
As far as the sliders, they are designed to mount on the factory frame rails, I'm expecting to have to modify the bracket slightly to work with the frame stiffeners from my Clayton kit. Specifically the angled bracket on the back frame mount you can see in the second picture. That angle is going to have to go away.
post #539 of 845 Old 06-30-2013, 06:02 PM Thread Starter
dillonjm
2013 WK
post #540 of 845 Old 06-30-2013, 06:10 PM
MoonyJohn
Sliders are the best mod for dubs. I banged mine up pretty good and i had 35's and 6.5" lift too.
Looks good as always
MoonyJohn is offline
