2001 on 37s - Building it up - Page 16 - JeepForum.com
post #226 of 845 Old 05-19-2013, 12:03 PM Thread Starter
dillonjm
2013 WK
Originally Posted by mtnmarc View Post
your track bar is short, and you drag link is gunna be longer due to the extra width. it will cause some flex steer.
Yeah, there may be some bumpsteer.
I'm not sure how, with the bracketry I'm using, I could have avoided the shorter track bar and still kept it parallel with the high steer.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #227 of 845 Old 05-19-2013, 01:57 PM
clgielin
2003 WJ
I see the abs cables hanging there. What are the plans for those? Are you going to attempt to keep the abs system?
Chris
2003 WJ 4.7L
Build Thread Here:
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #228 of 845 Old 05-19-2013, 02:06 PM
MStaffin
Whos front truss? TnT
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline
post #229 of 845 Old 05-19-2013, 03:35 PM
AgitatedPancake
Looks pretty similar to the TnT truss I put under the 1 ton ZJ. Unfortunately as Dillon said that track bar location is not great, and makes you end up with a short track bar as I did. It did have annoying bump steer unfortunately, even though I used inverted T steering which shortens the drag link a bit. Having true high steer with the drag link running to the knuckle will make it more apparent. I would definately add a steering stabilizer to your setup to soften the bump steer if you can. Another thing with coil springs and true high steer is the fact that there is NO room between the coil spring and tie rod when you are close to full lock, definately no room to squeeze a track bar past the coil.
You can make a frame side bracket that pushes the track bar out towards the wheel as far as possible like I did on Marc's build, but you can't go too crazy with it because you dont want to be close to the tire.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #230 of 845 Old 05-19-2013, 09:32 PM Thread Starter
dillonjm
2013 WK
Yeah, I'm probably going to modify the frame side like I mentioned a few posts a back. Gotta get the knuckles, hubs, tires on to see how much room I have to extend it.
Really nowhere else to go with the axle side with the coil placement. Suppose that's another plus to coilovers.
The Jeep won't be seeing DD duties but that doesn't mean I wouldn't like to get the geometry as good as possible for when it does see pavement.
dillonjm is offline
post #231 of 845 Old 05-19-2013, 09:33 PM Thread Starter
dillonjm
2013 WK
ABS is a gonner. I'll be getting the speed signal from the 231. Haven't disconnected the front cables yet.
dillonjm is offline
post #232 of 845 Old 05-19-2013, 09:35 PM Thread Starter
dillonjm
2013 WK
Yep.
dillonjm is offline
post #233 of 845 Old 05-19-2013, 10:05 PM
wj4play
Just saw this, looks great. Your going to love those 37's I know I love mine.
Sent from iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #234 of 845 Old 05-19-2013, 10:14 PM
mtnmarc
Have you looked into detail the wiring for the VSS?
I've found a good site, but haven't been able to find it lately.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #235 of 845 Old 05-19-2013, 10:17 PM Thread Starter
dillonjm
2013 WK
http://mallcrawlin.com/forum/showthr...ge-requirement
dillonjm is offline
post #236 of 845 Old 05-19-2013, 10:18 PM Thread Starter
dillonjm
2013 WK
Sent from iPhone
Thanks!
dillonjm is offline
post #237 of 845 Old 05-21-2013, 10:05 PM Thread Starter
dillonjm
2013 WK
Waiting on some minor parts to assemble the front outers and brakes.
Worked a little on the front bumper, brackets painted and bolted up and painted the lower radiator skid. Depending on when parts arrive I'll mount up the bumper and trim the wheel wells and get it painted too this week. Pictures once its mounted up for good.
dillonjm is offline
post #238 of 845 Old 05-22-2013, 07:50 PM
Peediz
Is the hitch that came off your WJ still available? What about the wiring harness and bezel?
02 Overland
Peediz is offline
post #239 of 845 Old 05-22-2013, 09:22 PM Thread Starter
dillonjm
2013 WK
No and no. Sorry.
dillonjm is offline
post #240 of 845 Old 05-22-2013, 09:35 PM
Peediz
Thanks anyway.
I can't wait to see your Jeep when it's done.
02 Overland
Peediz is offline
