2001 on 37s - Building it up - Page 14 - JeepForum.com
post #196 of 845 Old 05-10-2013, 08:49 AM
adavis39
hell i couldnt even get mine in the garage with 6'' lift and 35's without taking my roof rack off haha
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #197 of 845 Old 05-10-2013, 08:57 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
What TC are you going with?
Something to keep in mind is when measuring your drive shafts, see if you can get them the same approx length. Mine are within a 1/2" of each other and thus interchangeable (assuming you'll have the same size u-joints on both ends).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #198 of 845 Old 05-10-2013, 09:10 AM
ZB_WJ
Lookin' good!
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #199 of 845 Old 05-10-2013, 01:33 PM Thread Starter
dillonjm
2013 WK
Originally Posted by ChrisHager View Post
15" to spare from stock and you're going to 6.5" of lift and 37's (6" gain from tires). You'll be only about 5"-6" from rubbing after removing the roof rails. You might need some pull down winches if you ever throw on a roof rack!
Only gaining 4" from tires. Its only half the difference in diameter and I had 29" equivilents. Plus the 37s are closer to 36.5 than 37.
Not going to use a roof rack, its too tall to throw **** up there IMHO.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #200 of 845 Old 05-10-2013, 01:35 PM Thread Starter
dillonjm
2013 WK
231HD. I'm having JB build it instead of sourcing parts, more expensive but I end up with a brand new tcase.
dillonjm is offline
post #201 of 845 Old 05-10-2013, 02:32 PM
ChrisHager
Administrator
ChrisHager's Avatar
I can't math well today. Hahaha.
That would suck climbing up there. You'd have to fab up a fold down ladder in the rear!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #202 of 845 Old 05-11-2013, 08:50 PM Thread Starter
dillonjm
2013 WK
Didn't get as far as I wanted today, decided to work more on the rear instead of getting ahead of myself and putting the front axle in.
Got the shocks and sway bar mounts burned on, got the ox cable attached:
Rebuilt the passenger hub and installed it and the rotor:
Then I installed the passenger axle shaft and tire to free up another jack stand for the front. Screw mockup, this is with the jeep sitting on its own rubber, well, one at least..
My very pregnant wife is wondering how the hell she's supposed to get in..
I'm glad I went with 5" backspacing. Keeps the width in check.
Going back to the drawing board on brakes, going to figure out what ones were on it, the inside pad is too thick to clear the caliper bracket with the set I tried. That's why only 4 lug nuts, this will have to come off when I get to the brakes.
dillonjm is offline
post #203 of 845 Old 05-11-2013, 08:53 PM
TJSWJ
Nice work! Your making it look too easy? What is the original axle width, and why the spacers?
TJSWJ is offline
post #204 of 845 Old 05-11-2013, 08:54 PM
CRJEeP_wj
That's looking amazing, great job. Congrats on the pregnant wife, when is the due date? Ours is due mid June so my wife is shaped like yours. Haha.
CRJEeP_wj is offline
post #205 of 845 Old 05-11-2013, 09:58 PM Thread Starter
dillonjm
2013 WK
Long story short, the axles I bought without double checking the sellers belief weren't originally out of the same truck. I thought they were both from a 78 F250, turns out the front is but the rear is from a 68, based on the BOM number.
The '68 is 3" narrower than the '78 axle, hence the 1.5" spacers to get the width right to pair with the front 44. The '78 is ~67" wide, the '68 is ~64" wide (WMS to WMS), the front is ~69.5" for reference.
Then there was the whole shaft spline difference issue..why I ended up getting chromo shafts. BL, run the BOM on axles you're buying to make sure you know what you have.
dillonjm is offline
post #206 of 845 Old 05-11-2013, 09:59 PM Thread Starter
dillonjm
2013 WK
First week of Aug. Congrats to you too, this is our first so its all new to us.
dillonjm is offline
post #207 of 845 Old 05-11-2013, 10:04 PM
CRJEeP_wj
Boy or girl? We're havin a girl this time, We have a 3yr old boy already, they drive you crazy but you never regret it. Have you used an ox locker before? I wanna replace my arb, too many problems, and I wanna try an ox with a cable.
post #208 of 845 Old 05-11-2013, 10:11 PM Thread Starter
dillonjm
2013 WK
Having a boy, we are starting to get pretty excited.
This is actually my first set of selectables, ran auto lockers on my last three rigs, I'm a slow learner. Went with OX because they are made in the US.
I am going to run the electronic actuators and mount them in the spare tire area once I get that piece of sheet metal back on the Jeep.
dillonjm is offline
post #209 of 845 Old 05-13-2013, 07:01 PM
clgielin
2003 WJ
Looks good Jerrod! I sold my '92 YJ for more room after our third was born. It looked strangely familiar to yours...
Chris
2003 WJ 4.7L
Build Thread Here:
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #210 of 845 Old 05-13-2013, 08:06 PM Thread Starter
dillonjm
2013 WK
Thanks, nice looking YJ.
No work today or tomorrow. Spent most of the day in Ft Worth, will spend most of tomorrow in Baltimore.
dillonjm is offline
