1999 WJ project - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 1999 WJ project
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-09-2015, 01:25 PM   #1
Russellt198
1999 WJ project
Hey guys, new to the site but not to forums. going to do a little build thread here of my new to me 1999 WJ i picked up as a project.
needs some work but i have big plans
as of right now she needs:
a good tune up (200k on the clock)
gonna flush the fluids all around
rear end is noisey going to get a aussie locker for her
heat doesn't work. going to try to fix the blower motor issues and go from there
needs a front driveshaft but that will come after the following...
plans are:
IRO 6.5" long arm kit
lockers front and rear
242HD Tcase with SYE
new front driveshaft to accommodate lift
moab wheels with some 33" rubber
eventually id like to put a bigger front axle in and maybe even a rear. well see how this part goes for now. i would love to find some JK rubicon axles but i don't have that kind of money to play with just yet.
and here are some teaser pics
1999 WJ Limited 4X4 4.7L project
2006 Dodge Ram 2500 Diesel. daily driver tow pig
Russellt198 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 08:32 PM   #2
99WJ539918
Looks good. Sounds like nice plans. Good luck.
99WJ539918 is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 03:24 PM   #3
SteeleJay
Vulcan Ambassador
SteeleJay's Avatar
How committed are you to the IRO lift? I only ask because I was able to put together a RC LA kit w/Rusty's springs/shocks and JKS trackbar for significantly less than the IRO kit. You could even upgrade to Bilstein 5100 shocks and still be less than the IRO kit. The RC kit also includes a t-case skid. The RC bushings are greasable/rebuildable.
And no, I don't work for Rough Country - I'm just very pleased with my setup and thought I'd pass the info along.
Stress is the result of the mind overriding the body's desire to use a hammer to make a part fit where it was supposedly designed to fit.
I Jeep, therefore I swear.
SteeleJay is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 08:21 PM   #4
energeticmister
Promising plan you have there. I also hope you fix the seats too. Good luck man!
2001 Jeep Wrangler Sahara
energeticmister is offline   Reply With Quote Quick reply to this message
