1996 MAP sensor Cleanable? - JeepForum.com
post #1 of 4 Old 04-21-2009, 09:33 AM Thread Starter
T Hoff
1975 CJ5
I know in many Injected cars you can clean the Sensing wires inside the Mass Air flow sensor/ Air Mass Monitor, whatever you want to call it.
Can you do this on the '96 Cherokee 6 cyl?
Car idles badly, was recently tuned (plugs wires) but still runs crappy.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #2 of 4 Old 04-21-2009, 08:16 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i've never had good luck cleaning maf's before.
that said, the map sensor is a lot different. it uses a diaphragm to determine manifold vacuum.
ratmonkey is offline
post #3 of 4 Old 04-21-2009, 11:46 PM
Haleyrz
hmm, i was wondering about cleaning the MAP sensor too. Anyone?
1998 ZJ Laredo, 4.0L, 2WD, it's boring
Haleyrz is offline
post #4 of 4 Old 04-22-2009, 06:19 AM Thread Starter
T Hoff
1975 CJ5
I will give my Brother ( His jeep) the Haley IAC cleaning write up and let him go from there.
Thanks
T Hoff is offline
1996 Jeep Grand Cherokee Limited Crank Position Sensor mbg-jeep ZJ Grand Cherokee Forum 7 07-18-2010 08:46 PM
1996 JGC coolant sensor bad? ciarashutt ZJ Grand Cherokee Forum 5 12-08-2009 04:45 PM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
1996 GC speed sensor leaking fluid jetdude ZJ Grand Cherokee Forum 2 01-04-2008 08:23 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 04:52 PM
