1995 jeep grand Cherokee alarm issues - JeepForum.com
post #1 of 2 Old 01-08-2014, 06:18 PM Thread Starter
redsoxfeen
I lost the key with the alarm remote a while ago / I just went outside to try to start the truck and nothing i locked the truck from the inside i get out and the security light is still flashing / I get back in tried to start it nothing
redsoxfeen is offline
post #2 of 2 Old 01-09-2014, 01:19 PM
sk8rgrl
I had this same issue on my 95 grand cherokee and it was a pain. It kept alarming and the dash light would keep flashing. Also it has an ignition kill so you can't start it if the alarm is set off. I googled how to disable mine and it worked very easily. you just won't have an alarm on your car anymore. hope this works for you as it did for me. good luck
Also: on the drivers side door only, you can turn the key to the right and it turns the alarm off without a remote if you are not going to disable it completely
The FACTORY ALARM DISARM WIRE IS
purple/yellow |-| in the driver kick panel area,
at the black plug.
Once Located, splice into this wire with
a similar guage wire, and put it to
a solid chassis ground. This terminates
the alarm functions entirely.
sk8rgrl is offline
