'10 S-Limited Build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > '10 S-Limited Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOfficial Chassis Saver Rust Preventive Truck & Auto UnFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 02-21-2011, 03:24 PM   #16
AJeepZJ
2006 WK
Oh...My... Gawd!!! That thing is hot!
All Gear, No Skill.
AJeepZJ is offline   Reply With Quote
Unread 02-21-2011, 04:48 PM   #17
jager00
2005 WK
Very nice!
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline   Reply With Quote
Unread 02-22-2011, 02:37 PM   #18
Acidcold
2005 WK
Insane!
Acidcold is offline   Reply With Quote
Unread 02-22-2011, 04:04 PM   #19
CoreyZ
Very nice build thread man! That jeep looks MEAN!
'12 JK COD:MW3 Edition
'10 WK, Black(sold)
Colorado Jeep Club member #217
CoreyZ is offline   Reply With Quote
Unread 02-22-2011, 04:13 PM   #20
squashman702
1994 ZJ
Did you remove the recovery points off the front of the ARB?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote
Unread 02-22-2011, 06:38 PM   #21
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
2010 WK
Nothing really new today due to work... Just did a little bit more cutting for the grill and wheel wells. Hopefully I'll get a lot more accomplished tomorrow with more pictures!
Nope, they are part of the frame bracket. I was sure that they were not disturbed even as much as I've cut away. Here you can see them even after I've cut off the bumper attaching points hanging down low:
2010 Grand Cherokee S-Limited 5.7L QD-II
Modified AEV/Superlift 5" + EGR - 17x8.5 AEV Savegre JK wheels - 305/70/17 Goodyear MT/R w/ Kevlar - bobbed ARB bull bar - Kicker audio upgrade w/
single sub and MYGIG Lockpick - 4XGuard rear and side skids and sliders - ARB onboard air - Gibson cat-back - K&N 63 Series intake
1998 Cherokee Classic 4.0L AW4 NP242
under construction
USN_BlackWK is offline   Reply With Quote
Unread 02-22-2011, 07:41 PM   #22
Lt_JWS
2006 XK Commander
amazing Jeep! very nice write up aswell!
2006 XK 4.7V8 | Quadra-Drive II | Daystar 2" Lift |K&N Filter | Port and Polished Throttle Body| Magnaflow# 12256 | IAT Mod | Leather, heated seats,Command View| Factory Tow hooks | Full factory skids | Rear D-Ring Shackle
Lt_JWS is offline   Reply With Quote
Unread 02-23-2011, 01:22 PM   #23
WK-916
Nice ******* rig dude!!! wish mine was that nice...
It looks almost too pretty to take it wheeling....
So you think you can rebuild a 10' Hemi with your eyes closed? with the VVT and all?..... talented..... what if I took all the main caps and turned em backwards?.....
WK-916 is offline   Reply With Quote
Unread 02-23-2011, 03:10 PM   #24
USN_BlackWK
FLY NAVY
2010 WK
Touche Meh I could at least stumble my way through the rebuild... possibly
under construction
Unread 02-23-2011, 03:36 PM   #25
WK-916
well anyways..... NICE *** JEEP broski!
Im jealous.... and so is my JGC
Unread 02-23-2011, 03:38 PM   #26
WK-916
That front bumper looks like something off of a Diesel F350 or Cummins Ram 3500
Looks beefy....!!! I like!
Unread 02-23-2011, 05:55 PM   #27
USN_BlackWK
FLY NAVY
2010 WK
Not much to update in the last two days. Strangely work is taking up the majority of my time... I did, however, manage to get in a few hours.
I cut off the end caps:
And finnished the cut for the 08-10 grill:
I had to cut an inch out of the hoop brackets for grill clearance. I cut some pieces of 1/8" steel to blend into the metal.
And welded them up:
I made some templates for new end caps and decided to call it quits for the night. The new end caps are going to be recessed such that the fender liners can mount like the stock 08+ ones do (that's the best I can describe it for now) on the stock bumper.
under construction
Unread 02-25-2011, 04:42 PM   #28
USN_BlackWK
FLY NAVY
2010 WK
Progress!
I figure I have almost 30 hours into this project at this point. Definitely more work than I had originally planned. I started today by mounting up the bumper to finalize the position of the 08+ headlight fillers. I also trimmed up the underbumper pieces:
Unfortunately the windshield washer resivour is partially exposed. I decided I'm not going to worry about it, as its not a very vital part.
I made some recessed bumper endcaps and trimmed the fender liners to fit:
I welded up the headlight fillers:
Test fit:
Done for the day. On to bodywork and hopefully paint tomorrow!
The removed metal:
I estimate it at 20 or 30 pounds!
under construction
Unread 02-26-2011, 09:35 PM   #29
USN_BlackWK
FLY NAVY
2010 WK
Today I did the body work. A little body filler:
Sanded and primed:
Paint:
under construction
Unread 02-27-2011, 10:31 AM   #30
USN_BlackWK
FLY NAVY
2010 WK
Soooo close!
under construction
