1.500" >> 1.170" - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 1.500" >> 1.170"
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 07-03-2012, 05:49 PM   #1
KingtheZJ
1.500" >> 1.170"
The ZJ is no longer a DD. Changes are going to come fast. A new build thread is in order.
Old build thread:
http://www.jeepforum.com/forum/f197/...hread-1158916/
The Plan:
5" lift (3 link / triangulated 4 link)
79 HP60
14Bolt welded
37s
5.38 gears
Compcut
Flat belly pan
Frame stiffeners
d60-d30.jpg   480396_10151094261123273_501916296_a.jpg   523574_10151061765433273_1371135542_n.jpg   166039_10151083466428273_604587221_n.jpg
'98 ZJ with stuff
Build Thread
http://www.jeepforum.com/forum/f197/1-500-1-170-a-1388735/
KingtheZJ is offline   Reply With Quote
Unread 07-03-2012, 05:52 PM   #2
biggoofy
Local *******
biggoofy's Avatar
Looking forward to it man
Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
My Build
Need quality parts call Andy at Ironman4x4fab!!!!!
http://ironman4x4fab.com/index.html
biggoofy is offline   Reply With Quote
Unread 07-03-2012, 10:04 PM   #3
Bama_WJ
Bama_WJ's Avatar
Can't wait to see progress on this!
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel.
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- WJ JKS Shock Conversions
- OEM WK Springs
Bama_WJ is offline   Reply With Quote
Unread 07-05-2012, 10:21 AM   #4
squashman702
Mongo-fabbed
squashman702's Avatar
1994 ZJ
Nice- what are the plans for tires?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote
Unread 07-05-2012, 02:23 PM   #5
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Nice, sounds like a plan!
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog 404 portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear,...
http://www.jeepforum.com/forum/f11/h...ternal-973910/
Timo_90xj is online now   Reply With Quote
Unread 07-05-2012, 03:29 PM   #6
sadass
5.9,242,4.56,Aussies x 2
sadass's Avatar
on paper the difference between the two numbers seems so nominal, till you compare as you did with the pic. That should hold up to a bit more abuse. Good luck with the build. looking forward to seeing where this goes.
Military Jeepers.Com.
Jeep Forum member since 2/2002
5Nine=No replacement for Displacement
sadass is offline   Reply With Quote
Unread 07-11-2012, 10:58 AM   #7
xjh3
Any updates? I know the answer, but this is one of the few threads on the internet with pictures I can see at work.
xjh3 is offline   Reply With Quote
Unread 07-11-2012, 11:04 AM   #8
KingtheZJ
haha noooo i'm slow
progress was derailed by a purchase of a second 78 d60. which turned out to have a cracked driver side knuckle. 30 year old kingpin studs are suborn as ****.
'98 ZJ with stuff
Build Thread
Unread 07-11-2012, 12:00 PM   #9
AgitatedPancake
Sucks about the knuckle man, I plated the crap out of mine to make sure nothing bad happens like that. The build looks sick though!
Soak that kingpin in penetrating lube or WD-40, then get yourself a LONG breaker bar for that allen wrench hehe.
The first one on Andy's '79 went easily,
The second one didn't want to come off, I had to use the full weight of the axle housing plus my welder on top of it to break it loose haha
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote
Unread 07-11-2012, 12:12 PM   #10
KingtheZJ
the crack isnt too bad. i'll grind it out, weld it, and plate it. you think its worth getting that $75 plate kit off pirate or just torch some pieces out of .25" plate myself? any advice for welding on the knuckles? was was going to preheat them in the oven (mom is going to be elated!) and use .035 flux core on 180 amp.
i've been following your build forever. ever time i look at the front of the jeep i think about how to dovenose it. haha
'98 ZJ with stuff
Build Thread
Unread 07-11-2012, 12:16 PM   #11
KingtheZJ
not the best, but you can see it
'98 ZJ with stuff
Build Thread
Unread 07-11-2012, 06:58 PM   #12
AgitatedPancake
haha shoot thanks man! I preheated my knuckles with oxyacetylene, welded HOT 2"ish strips, then peened (hammered, landing specifically on the weld and the cast area around the weld) the fresh strip of weld. From there either weld the next strip or oxyacetylene post heat. I've had good luck so far, make sure you've got it preheated nicely not just blast it a little bit.
Unread 08-01-2012, 03:58 PM   #13
Dyn0mitemat
Y u no update???
98 ZJ: Built 44/88, long arm'd, locked, 35s, armour, blah blah blah
Build Thread: http://www.jeepforum.com/forum/f22/green-zj-aka-jolly-green-giant-1386118/
Dyn0mitemat is offline   Reply With Quote
Unread 09-19-2012, 01:58 PM   #14
KingtheZJ
this is not happening fast at all....
got some stuff, not enough
d60 rebuild parts
14b
36" TSLs
H1s
ballistic coil buckets
new plan is to run stock 4.10 gears and 36s then upgrade later. need to get this going.
'98 ZJ with stuff
Build Thread
Unread 09-19-2012, 02:04 PM   #15
biggoofy
Local *******
biggoofy's Avatar
The waiting game sucks man. I hated it during my build.
Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
My Build
