07 Jeep Limited 5.7 dies - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 07 Jeep Limited 5.7 dies
Rough Country Lift Kits and Parts!Ruffstuff Axle Simple Swap Kit!Don't forget the Jeep Forum discount, 10% off!
Unread 12-10-2013, 04:08 PM   #1
TimsJeep07
I have an 07 Jeep limited with the 5.7 Hemi engine. I come to stops and it will just die like someone just turned the key off. It's happened several times. The common factor is that it's normally at idle or just coming to a stop when it happens. There is no bucking or gradual decline, it just stops dead and then I can start it right back up. I took it to a Jeep dealership and the got it to throw and they changed a shutoff relay. Got it home and it died in the drive. I have read it could possibly be a crankshaft position senor, any thoughts?? thanks in advance
TimsJeep07 is offline   Reply With Quote
Unread 12-10-2013, 08:51 PM   #2
Jeepforthewin
Lucky Charms!
Jeepforthewin's Avatar
2005 WK
Id replace the CPS like you stated. I had the same problem and replacing the sensor fixed it! Cheap and easy DIY.
LOOKING TO BUY: RRO or JBA UCA's
Jeepforthewin is online now   Reply With Quote
