'05 Grand Cherokee ABS problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > '05 Grand Cherokee ABS problem
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 01-14-2015, 04:15 PM   #1
1992sea
Recently, the ABS and traction control lights popped up on my '05 JGC Limited. Mechanic pulled the code C1035 and said it was probably a short between the ABS module and right rear wheel sensor, but was going to charge an arm and a leg to diagnose exactly where the short was. I've read online that some people just replace the sensor and the problem goes away, but that wouldn't be the case if I have a short. How do I locate the short and if the wiring is bad, how do I repair/how expensive is the repair?
Thanks.
1992sea is offline   Reply With Quote Quick reply to this message
