04Overland47's WJ Build Thread - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 04Overland47's WJ Build Thread
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-27-2013, 07:44 PM   #91
04Overland47
04Overland47's Avatar
Greased up the end links and bolts, all is quiet with the bar now!
2004 WJ Overland 4.7HO Graphite ~122k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / 17" Moabs
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
04Overland47 is offline   Reply With Quote Quick reply to this message
Unread 07-09-2013, 03:28 PM   #92
04Overland47
It was time to change the diff fluids and transfer case fluid again...well, not really but i scored a good deal on some Redline fluid and I'm picky about maintenance. Pulled the cover on both diffs and found no signs of premature wear on the gears Again, the fluid used was Redline GL-5 75w-140. Also put a Lubelocker on the Dana 30, so much easier than the RTV. Good days work!
Lifted Jeep
Front diff
Rear diff
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 07-12-2013, 06:39 AM   #93
paroxysym
2007 WK
ever get your injector issues solved? id try a can of seafoam through the tank and run one through the brake booster line- that has been proven to help peoples idle issues as well as any fouled up injectors.
also, great build thus far- love the subtle mods. i went the same direction you are going when i had my 02 WJ- bilsteins at all 4 corners, UC springs and rear addco. never got to install the mods, as i totalled it a week after i got all my parts in.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 07:24 AM   #94
04Overland47
Well I did have new injectors installed a while back around the 100k mile mark, but that didn't help the low idle. It's funny because when the Jeep is tuned via Superchips, it ALWAYS idles right at 600 where it should. But if I take the tune away and set it for stock, the idle will dip down to 400-450 at stop lights and such. Has me wondering if a part that the Superchips tune tunes is not working correctly . Next on the list is replacing the fuel filter (which actually came in the mail yesterday).
Thanks for the comment! I would love to actually lift it, but it's a daily driver and I don't have the time or money to fix old suspension parts if they start to fail after the lift. It's nice to hear that someone else appreciates the subtle upgrades I have done.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 07-12-2013, 08:52 AM   #95
paroxysym
2007 WK
gotcha. i probably would have gone the seafoam route. what about a vac leak?
OEM+
Unread 07-12-2013, 02:47 PM   #96
04Overland47
I'm not really a fan of Seafoam or any type of additives when it comes to the engine. For some I hear it works wonders, but for others I hear nothing but horror stories. The negative reviews may be because they didn't follow a certain procedure or overused it in some area, but I am not willing to take that chance. Other than the idle, the Jeep runs extremely strong and smooth so I'm not too worried about it.
I haven't checked for a vac leak yet, but me and a couple other WJ guys kind of ruled that out when we discussed the problem in detail. Plus, like I said, it only dips down when the Jeep isn't tuned with Superchips...so if it was in fact a vac leak, I would expect the idle to dip down all the time regardless of the tune. It is a very strange thing, but I always have it tuned so I don't experience it anymore.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 07-12-2013, 02:57 PM   #97
compcrasher86
It's really just buggy programming the WJ PCM is a very primitive JTEC based design that is known for having bad idle control. My roommate did something with his restrictor plate or tweaked the TB a little to get rid of it on his 5.9 but I wouldn't recommend messing with it too much.
I ran Seafoam through my WJ and its been eerily quiet and smooth for a good 30k now but its starting to make some valve noise again so I might give it another go. I would not put it in the crankcase I do fuel tank and feed through the vacuum hose.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 01:43 PM   #98
paroxysym
2007 WK
id throw it in the crankcase and run it a 100mi and then do an oil change to get all that gunk out of there. the fuel line and the brake booster helped me with a fouled up plug and a misfire on my 4.7.
OEM+
Unread 07-29-2013, 10:38 PM   #99
04Overland47
Finally got some time to "fix" something that has annoyed me since the day I bought it...the faded rear bumper pad.
Before
After
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 07-30-2013, 12:37 PM   #100
paroxysym
2007 WK
you could have bedlined it, what did you end up using??
OEM+
Unread 07-30-2013, 02:49 PM   #101
04Overland47
I was going to use the left over bedliner I had from the rock rails, but decided to just use matte paint. It's Duplicolor Trim Paint. Did some trim pieces on the ZJ too and I'm really happy with the way everything came out.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 07-31-2013, 09:46 AM   #102
paroxysym
2007 WK
hmmm i have to look into that. i was going to do my door trim in bedliner and redo my rear step pad in bedliner. i used some rattle can liner and it didnt hold up well. may go raptor next lol.
thanks for the suggestion
OEM+
Unread 07-31-2013, 04:28 PM   #103
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
The bumper pad turned out really well, good work. Looks much better!
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2013, 06:48 PM   #104
04Overland47
Next on the summer "to do" list were new brake pads and rotors all around. The brakes really should have been addressed soon after i bought it but now, 20k miles later, they were starting to squeak. The old pads were worn way below the wear indicator. Now she has Napa Premium rotors and Duralast Gold Cmax ceramic pads. Brake feel and stopping power is A LOT better . Also got a new WIX fuel filter.
OLD: Notice the small chunks missing from 2 rotors
NEW
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 08-09-2013, 07:33 PM   #105
gcjeeping
gcjeeping's Avatar
Looks like someone beat the rotor off with a hammer.
__________________________________________________ _________
-GCJEEPING's build/mod thread-IT'S A GREEN THING...
gcjeeping is offline   Reply With Quote Quick reply to this message
