04Overland47's WJ Build Thread - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 04Overland47's WJ Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-08-2012, 10:05 PM   #46
snobrdrkid07
snobrdrkid07's Avatar
Originally Posted by 04Overland47
Yes sir!
Yup. I had 100w low beams and high beams when I had my stock lights
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 09-08-2012, 10:41 PM   #47
04Overland47
04Overland47's Avatar
They are so much better than the factory bulbs. No yellow tint/haze, nice and clear..and bright
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
04Overland47 is offline   Reply With Quote Quick reply to this message
Unread 09-08-2012, 10:48 PM   #48
snobrdrkid07
Oh for sure, I hate yellow head lights. I've got to have stupidly bright white lights. Why I had to go with hid's
-Michael-
Unread 09-08-2012, 11:56 PM   #49
04Overland47
The niner has true HIDs...bright as hell haha you can see that thing coming from miles away!
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 09-08-2012, 11:58 PM   #50
snobrdrkid07
Oh sweet! Did someone do a projector retrofit?
And that's how everyone who knows me ID's my Jeep at night. The lights are brighttttt! Haha.
-Michael-
Unread 09-08-2012, 11:58 PM   #51
compcrasher86
You can see it coming but can you see anything else on the road? HIDs are a touchy topic because a lot of people do em wrong and they blind others. I'm sure I'm not the first to ***** and moan about it.
Matt
compcrasher86 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2012, 12:07 AM   #52
04Overland47
After that text you just sent me, i'm not sure i want to answer this question lol.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 09-09-2012, 01:08 PM   #53
04Overland47
Believe it or not, i think the PO angled the lights downward. They point just a tad more to the ground then the WJ's lights. Not sure if that's just how the ZJs are or if was set-up like that after the HID conversion.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 09-09-2012, 01:16 PM   #54
04Overland47
All this talk about power steering fluid got me worried...so today i checked mine out and found that it is infact the Mopar fluid (thank god ). However, i also found that it has dexcool coolant instead of the Mopar coolant or Zerex. Going to wait to replace it until it hits 100k (as i will be replacing all fluids at that mark). The coolant only has about 1500 miles on it as of now, so i don't see a major problem running it for another 4k miles.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 09-17-2012, 08:32 PM   #55
snobrdrkid07
I'm at a toss up if I should change out the ATF in the P.S. system, I don't have the hydro fan in my Jeep and its been running ATF now for 50k miles. Probably wouldnt hurt to go ahead and do a good flush and replace with Mopar PS though.
I want to do the coolant in my Jeep too and flush it all out and put G05 in it.
-Michael-
Unread 09-17-2012, 08:59 PM   #56
04Overland47
Did it have the ATF from the factory? I remember that was a possibility being thrown around your build thread, but now you say it's only been in there 50k miles. I have to agree with you, using the Mopar fluid wouldn't hurt and it would give you peace of mind.
Did you ever find out what coolant is in it now?
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 09-17-2012, 09:06 PM   #57
snobrdrkid07
I am not sure what was in it from the factory, but the dealer that we bought it from (reputable) did the p.s. fluid. Who knows.
Ummm, coolant is red...
-Michael-
Unread 09-17-2012, 09:21 PM   #58
04Overland47
Best bet would be to drain and flush the system, no? Even if you don't NEED the Mopar PS fluid, i would think it provides more protection and less wear then ATF? Just guessing.
Could be the recommended coolant, or worse, Dexcool . Is it as important for the 4.0's cooling system to have the Mopar specific (or similar) coolant? I know for the V8's it's a must have, but I'm not sure about the I6.
2010 WK Laredo 5.7
Youtube Channel
WJ Thread
Unread 09-17-2012, 10:10 PM   #59
snobrdrkid07
Yes would be best to flush it all out, and the fill it with mopar power steering fluid.
Who knows, I know that the v8's have aluminum heads and need a coolant that wont corrode the aluminum. I6 is all cast iron and couldn't tell you if it needed a special coolant. Can't think off the top of my head.
-Michael-
Unread 09-17-2012, 10:44 PM   #60
compcrasher86
The V8s definitely should be running HOAT coolant, specifically Zerex G-05 should work for ya. Early i6s like mine were factory filled with Zerex green, non-g05. When you hit the mark to do your coolant make sure it gets power flushed or you get every trace of the old stuff out, it does NOT mix well with G-05. Later spec WJs V8 or i6 were factory filled with Zerex G-05/Mopar coolant which is gold/red.
Matt
