04 WJ Budget Boost - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 04 WJ Budget Boost
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-23-2015, 12:36 PM   #1
pipelayer_99
04 WJ Budget Boost
Put this lift on this weekend and I love the way it looks. (except the tires/rims) Got the Teraflex spacers off craigslist and custom built the bump stop spacers for the front from 1 inch square metal. Skyjacker shocks off morris4x4 and there is a $35 mail in rebate so all said and done lift was just over $200. Used wing nuts for easy sway bar disconnect, turned the lock nuts around on the end of the bolt so the wing nuts won't fall off.
I'm working on getting 17 inch JK rims for it. These should have been lifted from the factory.
10898199_10152685613531332_7568918792331612134_n.jpg   11071687_10152685613521332_3541977759763638879_n.jpg   11081490_10152685613526332_1285121467279845017_n.jpg
pipelayer_99 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2015, 12:40 PM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
WJ tech forum. Hmmmmm.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
