'04 2WD WJ Laredo to '04 4WD WJ "Limited" Build - Page 7 - JeepForum.com
post #91 of 138 Old 08-24-2013, 08:50 AM Thread Starter
JeepsOLot
Got the D30 stripped of the old style calipers and brackets, and painted the axle red, as instructed by the WJ's owner, my wife!! I plan on using her Jeep's '04 calipers and brackets as the axle is from a '00. Everyone else in our Jeep club likes to paint axle and suspension parts, so, she wanted them painted red to match her Jeep. This will be installed next weekend when our Jeep club has a work weekend.
At installation time, I also plan on replacing the outer axleshaft u-joints, that'll be fun!!
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #92 of 138 Old 09-02-2013, 12:10 PM Thread Starter
JeepsOLot
Ok, got a front skid plate for $15 at the junkyard:
Installed:
Here is the '00 D30 with Vari-Lok 3.73 gears installed:
Here's both together installed:
The D30 bolted right in, no mods. I swapped the '04 Akebono calipers, caliper brackets, rotors and the ABS sensors from the 2WD axle beam over to the D30, worked like a champ!! Now, have to figure out the drive shaft issues, and then on to the OD unit and 242 install.
Jerry
post #93 of 138 Old 09-22-2013, 04:35 PM Thread Starter
JeepsOLot
Just found out from WJ Jeeps that my driver's side heated mirror has the Auto Dimming function! I have a driver's side heated mirror, memory module, all four inner door panels, and auto-dimming inside rear view mirror from a '00 WJ. Reading the Mirror section of WJ Jeeps lead me to discover that there was an option that, with the auto-dimming inside rear view mirror, you could get the driver's side outside mirror with the auto-dimming function. These auto-dimming driver's side mirrors have "GNTX" engraved on the bottom center of the mirror glass. Low and behold, that engraving was on my mirror! I just have to wire the driver's side mirror to the auto-dimming inside mirror, and it should work.
Another thing I found out is, with the memory module in '99-'02 WJ's, the memory mirror function controls both driver's side AND passenger side mirrors! For the memory module for '03-'04 WJ's, only the driver's side mirror is controlled. On mine, I only got the '00 driver's side mirror, and not the passenger side (the '00 passenger side mirror was damaged), so, I have still have the '04 passenger side mirror. The '00 memory module on mine does not control the '04 passenger side mirror. When I originally installed the memory module, the driver's side seat motors didn't work either. More research lead me to switching out the driver's side seat track for the '00 seat track. The reason for it is, the '04 Laredo seat track motors did not have position encoders, which is needed so the memory module knows the position of the seat motors. This might be the same issue with the passenger side mirror, the '04 mirror did not have position encoders for the memory module.
I love WJ Jeeps!!!!
Jerry
post #94 of 138 Old 09-28-2013, 01:24 PM Thread Starter
JeepsOLot
Got a '00 passenger side mirror, and now, it works with the memory and is heated!
From what I can see, I have the correct wires going into the driver's side door plug from the body side for the auto dimming feature. I had to wire in the door the two wires that go to the door panel for that option. I hope it works, won't know until tonight.
Jerry
post #95 of 138 Old 09-28-2013, 05:42 PM Thread Starter
JeepsOLot
Test complete, auto dimming driver's side mirror works!! When I tested it, I used an LED flashlight. When I pointed it at the side mirror, it didn't dim. When I pointed it at the inside rear view mirror, the side mirror dimmed with the inside mirror.
Jerry
post #96 of 138 Old 10-07-2013, 03:59 PM Thread Starter
JeepsOLot
Well, got an RB1 installed:
Even got the Jeep to come up on the screen, it came out of a Dodge Ram:
Still need to get an AL Nav disc, a GPS antenna, the iPod integration kit, and the Sirius box.
Jerry
post #97 of 138 Old 10-12-2013, 02:47 PM Thread Starter
JeepsOLot
Finally got my RB1 AL NAV disc in the mail. Found out that the DVD mech in the RB1 is just fine! I bought it off eBay for $150 shipped because the NAV disc would not read. Found out that it will give a read error at first, then I switched to radio and back to NAV, the screen goes blank, and then, the disc starts updating the firmware. I'm so glad!! Now, need to get a GPS antenna.
Jerry
post #98 of 138 Old 10-17-2013, 07:39 PM Thread Starter
JeepsOLot
Got some 3/4" leveling spacers for the front.
Before:
After:
Jerry
post #99 of 138 Old 10-19-2013, 08:23 PM Thread Starter
JeepsOLot
The WJ got new shoes:
They are 265/70R17 Nitto Crosstek's on JK 17" rims. Good thing I put the 3/4" front spacers on, they wouldn't have fit without them!
Jerry
post #100 of 138 Old 10-21-2013, 10:15 AM
paroxysym
2007 WK
looks great, you plan on dipping the rims? i think theyd look great in a graphite to match the cladding.
good build!
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #101 of 138 Old 10-21-2013, 12:18 PM Thread Starter
JeepsOLot
I would like to, just don't know how to get the plasti dip to match the graphite.
Jerry
post #102 of 138 Old 10-23-2013, 12:36 PM
paroxysym
2007 WK
Jerry
check out the plasti-dip wedsite... there may be a shop in the area that specializes in dips and they could do you a custom color
OEM+
post #103 of 138 Old 10-25-2013, 01:46 PM Thread Starter
JeepsOLot
Well, good and bad news about the RB1. I got a burnt AL NAV disk from a guy on here. It looked like it was updating, it would finish, but, when you tried to use the NAV function, it would give a disk read error. Thinking it might be the unit, as the seller had the same issues, I checked with a radio guy in town. He thought the burnt disk was causing the problem, and I should try a Mopar disk. Well, went to Wallace Jeep in town, and they let me borrow a Mopar AC disk. It worked like a champ! I guess my radio is one of those that don't play well with burnt disks! Looks like I'm going to have to cough up $150 for the Mopar AL disk, OUCH! Anyone know where I can get a Mopar AL disk that is $100 or less? Thanks!
Jerry
post #104 of 138 Old 11-17-2013, 08:41 PM Thread Starter
JeepsOLot
Well, had to get the Mopar AL disk from the stealership, and IT WORKS!
Thank God, or, I would have paid $150 for nothing! I think I still came out ahead, $175 shipped for the RB1 and $150 for the AL disk puts me at $325. The closest I could have come to on eBay was $367 for a used RB1, PLUS shipping and that did NOT include the nav disk!
So, one more added option: factory in dash NAV system! Now, just need to get the iPod integration kit and Sirius Sat kit.
Jerry
post #105 of 138 Old 12-05-2013, 02:06 PM Thread Starter
JeepsOLot
Ok, a few weeks ago, I got the Bilsteins from Kolak, love the ride!
Front
Rear
I just got the IRO adjustable front track bar today, again from Kolak, hope I can get it on this weekend.
Jerry
1995 Laredo Weird "bucking" issues while driving jrsquared ZJ Grand Cherokee Forum 3 07-12-2011 07:20 AM
98 GC Laredo I6 with 4.5" Lift and 32x11.5" tires? Pilzner33 ZJ Grand Cherokee Forum 8 11-27-2010 05:23 PM
"Unintended acceleration" 2005 Jeep Grand Cherokee Laredo mknight WK Grand Cherokee & XK Commander Forum 11 02-23-2010 01:43 PM
"Grand Cherokee" and "Limited" emblems? jdwiseman ZJ Grand Cherokee Forum 14 02-04-2009 06:49 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 06:06 PM
