'04 2WD WJ Laredo to '04 4WD WJ "Limited" Build - Page 4 - JeepForum.com
post #46 of 138 Old 05-01-2010, 11:45 AM Thread Starter
JeepsOLot
Originally Posted by drwolcot View Post
Yeah no prob. Something you might want to consider since you are going to get the wood grain as extra is try to cut out the ashtray so your xm unit will all be flush (as long as you have steady hands).
Trying to picture what you are talking about. The ashtray door in mine is totally gone, it's mounted on the back of the compartment. I had to trim some off the sides so it would mount straight. I thought I took pics of it after I took the ashtray out, but before I put the XM in there, can't find them, though,
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #47 of 138 Old 05-01-2010, 11:51 AM
drwolcot
Keep it mounted to the back like you have it but if you still have the ashtray laying around cut a hole in the ashtray so just the face of you xm unit is flush with everything. It would look even cleaner
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #48 of 138 Old 05-01-2010, 11:56 AM Thread Starter
JeepsOLot
WOOHOO!!! Got the almighty blessing to put a "2 BB on!!
The wife knew that my YJ has a 2.5" lift, and she can't get into the thing! She forgot that I have 33" tires, 1" body lift, and 5/8" shackles adding to the height! Every time I say something about lifting her Jeep, it was a resounding NOOOOO!! I let her see some pics of WJ's with the 2" BB, and one pic with a stock WJ next to a WJ with a 2" BB, and, now, she's ok with it!! As I stated before, this is HER Jeep, and I want her to be OK with all the things being done to it.
Now, for bigger tires.......to be continued....
Jerry
post #49 of 138 Old 05-01-2010, 12:02 PM Thread Starter
JeepsOLot
I've already chucked the ashtray long time ago (I did this several months ago). When I get the new lower panel with the heater switches and the wood grain, I'll experiment with the ashtray door. If the ashtray mod doesn't come out the way i wanted, I can always scrap it, and go with what I have here, Thanks, again, for the idea!! It would look better, especially with the wood grain door.
Jerry
post #50 of 138 Old 05-07-2010, 10:29 PM Thread Starter
JeepsOLot
Update: Well, so much for the front axle!! I was at the yard earlier in the week, and the whole axle was there. We go to get it, only to find that the whole pass. side has been taken off, caliper, rotor, wheel bearing unit, steering knuckle, and even the pass. side axle shaft!! I told my wife that I didn't want to mix and match parts on the axle. It's either the whole entire axle, or nothing. I don't want various parts of different years, ages, and mileage. Even if I did get the thing and swapped out what was on the front axle beam, I'm still missing that pass. side axle shaft.
Oh, well, better luck next time,
Jerry
post #51 of 138 Old 05-17-2010, 03:06 PM
Marctwayne
Man I was just going to lock up the rear axle and lift it up a little. Now! I need to do some junk yard searching.
-- Marc Wilson -- 85 CJ7 Called Buster, Why? The wife likes to yell out the door "Are you done fix'en buster's bits yet"?
Originally Posted by my-jeep-earl View Post
It does look alot better when the Jeep is "ugly side up" though! :hahaha::teehee:
Marctwayne is offline
post #52 of 138 Old 05-29-2010, 01:15 PM
justkiddin
2003 WJ
Nice Work
justkiddin is offline
post #53 of 138 Old 12-05-2010, 11:28 PM Thread Starter
JeepsOLot
Thanks, guys! Now, while I'm waiting for a WJ D30 to show up at the yard, I had a little brain storming, and the wifey likes this. I saw a Columbia Edition '04 while we were in VA over the summer. We're REALLY diggin' the smooth graphite cladding for the bottom doors and both bumpers. I found an '04 Columbia on ePay today with the same Inferno Red body color!! Here are the pics:
Ours:
The Columbia:
The only part that I might have problems trying to get is the front bumper, with it being an '04. The rest I can get from Limiteds, Overlands, and Special Editions of any WJ year. I think it would look pretty good, plus, I won't have to worry about the fading issues with the Laredo cladding,
What do you guys think?
Jerry
post #54 of 138 Old 12-05-2010, 11:41 PM
madrabbitt
madrabbitt's Avatar
The door cladding is a pita to take off without damaging it.
You could just paint yours.
I used krylon fusion in charcoal that was pretty close to that color, bet you could get a silver color to get a lighter shade.
The krylon stands up pretty well to abuse, and it blends well to cover up damage.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #55 of 138 Old 12-05-2010, 11:45 PM Thread Starter
JeepsOLot
Well, so far, I have cladding for all four doors and the rear bumper with the trailer hitch bezel from an '04 Special Edition. You do have to be VERY careful in getting the door pieces off, but, i did fine,
Jerry
post #56 of 138 Old 05-06-2012, 10:51 PM Thread Starter
JeepsOLot
Well, got rid of the XM unit, and got the Burl wood finish lower bezel with the heated seat switches. Here is what it looks like now:
Hopefully, I will be getting the front and rear axles from the same donor WJ that had this bezel. The ratio for the donor is 3:73, and ours is 3:55, so both need to be replaced. One somewhat good thing is, I'll be upgrading from a D35 rear to a D44A rear, a somewhat better axle. I don't thing there will be anything I would do with this 4.0L to hurt it, so, I think it's a good move. I'll just have to make a rear drive shaft to make it work, as there is no application, that I know of, of a D44A with a 4.0L. Does anyone know if a 4.0L with tow package had the D44A, or, is it just behind 4.7L's?
Hopefully, by the end of the summer, I'll have the 4WD components installed and working,
Jerry
post #57 of 138 Old 05-12-2012, 11:43 PM Thread Starter
JeepsOLot
Ok, more Limited add-ons!! Got the auto-dim rear view mirror, auto headlight switch stalk with fog switch as well as the auto headlight dash sensor, and the taupe trim pieces around the steering wheel and under the gauges. I also got the Limited door panels installed. If you do swap out the door panels, remember that the receiver for your key fobs is in the passenger side door panel, in the door switch module. You will have to swap those so that you have your original door switches for your key fobs will work. Luck for me, I didn't get rid of them yet!!
Here is the door panels, as they are on an '04 Laredo:
And here are '00 Limited door panels installed on an '04 Laredo:
Here is the auto-dim rear view mirror:
As someone did say, my '04 Laredo had the plug for the mirror, it was tucked WAY up in the headliner board.
Here are the auto headlight switch with fog controls and sensor for the auto headlights:
The auto headlights were a plug and play, just that the plug for the light sensor was behind the instrument cluster, so, that needs to be moved before seeing the plug.
And, here are the last interior Limited pieces, WOOHOO!!
I also added a driver's side heated side mirror:
All of these pieces in this post came off of an '00 Limited. That's it for now!!
Jerry
post #58 of 138 Old 05-14-2012, 06:47 PM Thread Starter
JeepsOLot
Got the cladding pieces as well as the rear bumper and front bumper, in Graphite, from an '00 Limited. They need a little TLC paint-wise, but, I think it's a better match for what I'm trying to do. I would have to totally repaint the Dark Garnet Red cladding and rear bumper that I originally got. Came off the same '00 Limited that the interior pieces came from.
Here are the cladding pieces:
The front bumper:
And the rear bumper:
Jerry
post #59 of 138 Old 05-14-2012, 07:33 PM
TX-WJ
TX-WJ's Avatar
Kool, looks like you got urself a Columbia-Limited .
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is online now
post #60 of 138 Old 05-18-2012, 10:34 PM Thread Starter
JeepsOLot
Originally Posted by TX-WJ View Post
Columbia-Limited .
Should have used that for the name of the build, dammit!! LOL!!
Got the side cladding on as well as the rear bumper cover. Here are pics of the sides:
The pics of the rear bumper cover didn't come out too well, as it was dark when I finished it:
I'll take more pics tomorrow, as well as pics of switched front bumper cover, which I still need to do. I think it looks quite nice!! Externally, it'll look just like an '04 Columbia, except for the front bumper cover, since it's from a '00 Limited, it'll have the oval fogs instead of the round '04 ones.
Jerry
1995 Laredo Weird "bucking" issues while driving jrsquared ZJ Grand Cherokee Forum 3 07-12-2011 08:20 AM
98 GC Laredo I6 with 4.5" Lift and 32x11.5" tires? Pilzner33 ZJ Grand Cherokee Forum 8 11-27-2010 06:23 PM
"Unintended acceleration" 2005 Jeep Grand Cherokee Laredo mknight WK Grand Cherokee & XK Commander Forum 11 02-23-2010 02:43 PM
"Grand Cherokee" and "Limited" emblems? jdwiseman ZJ Grand Cherokee Forum 14 02-04-2009 07:49 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 07:06 PM
