'04 2WD WJ Laredo to '04 4WD WJ "Limited" Build - Page 3 - JeepForum.com
post #31 of 138 Old 01-08-2010, 06:15 PM Thread Starter
JeepsOLot
Well, not much has changed, but, I thought I would share a post on Mall Crawlin' about a 2WD to 4WD conversion that someone did to a ZJ. This swap involved a 42RE and the different OD Units that were swapped out and in. This is the basis for my conversion of the WJ. 2WD ZJ to 4WD ZJ It's not that hard, really,
Jerry
P.S., tfgnt16, the Jeep that had the gauge motors is gone, must have scrapped it, I'm sorry. I'll keep a lookout when I'm at the junkyards,
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #32 of 138 Old 01-19-2010, 07:47 PM Thread Starter
JeepsOLot
I got these stickers that my wife just HAD to have!
I got two of them and this is where I put them, one on each side:
Since this is the family mobile, it fits,
Jerry
post #33 of 138 Old 01-19-2010, 08:55 PM
madrabbitt
madrabbitt's Avatar
better then sticker that my ex had gotten for my cherokee, back in the day.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #34 of 138 Old 03-18-2010, 04:13 PM Thread Starter
JeepsOLot
Ok, FINALLY got the missing link for the leather interior, the dreaded driver's side front seat, WOO HOOO!
This is what the interior looked like before I took the seats out:
Now, I not only switched the seats themselves, I put in a passenger side motor track and wired for the power lumbar and recline on both, which the driver's seat was lacking. This makes both front seats true 10-way power Limited leather seats, .
Here is what it looks like now, front passenger seat and whole rear seat are from a '99 Limited, and the front driver's seat is from an '00 Limited:
I think it turned out great, and the wifey is pleased, ! Does anyone know a very good leather cleaner I can use, I have some stubborn places that need it. I used Black Magic Leather Conditioner and Cleaner, and it did better then I expected!!
Jerry
post #35 of 138 Old 03-18-2010, 04:45 PM
MoonyJohn
MoonyJohn's Avatar
Try just spraying the area, and then using a toothbrush or something..
MoonyJohn is offline
post #36 of 138 Old 03-18-2010, 04:48 PM
BransJeep
Try lexol cleaner and conditioner, i did this same swap that you did, except i used the newer seat style, looks good though!
-Brandon
4.0, 42re, 242
4.5 inch lift, front Ironman 4x4 adjustable CA's
RB1 and full J&L audio setup
Rola roof rack
BransJeep is offline
post #37 of 138 Old 03-18-2010, 05:31 PM
TX-WJ
TX-WJ's Avatar
This build is full of win!
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is online now
post #38 of 138 Old 03-18-2010, 08:29 PM Thread Starter
JeepsOLot
Thanks! Gotta love the CFC program, or all of this wouldn't be possible, , at least in this short of a time frame. Oh, to keep tabs on the prices, $75 for the driver's front seat (with $100 for shipping, ). Hey, I've been searching for that stupid seat for 6 months, I saw this on ePay, and jumped on it!!!
MoonyJohn, thanks for the tip, where would you find that, at Walley World or auto parts store?
Jerry
post #39 of 138 Old 03-19-2010, 09:18 AM
drwolcot
Just found your build thread... I posted awhile back on your thread when you were first thinking about doing the 2wd-4wd swap and you said that all the WJ's you found were gone from the JY... I assumed you gave up cause there were no following posts.... Glad to see you are still keeping it up.
Just to let you know.... I just finished my 2wd-->4wd swap 2 weeks ago..... it was really easy. You really got lucky with the CFC.. In my area I didn't have an yards that had any WJ's in them so I got most of my stuff from car-parts.com and a few stuff from the classifieds here.
When you start the swap and you need any questions feel free to ask me and I will help. Just for future reference... Since you TC has the flange for the front driveshaft for the CV make sure you get the bolts with the drive shaft. When I got my drive shaft the guy lost the bolts and they are mighty expensive from the dealer at $14 each pair. Depending on what yoke your front d30 has you could need 3 pairs for each end and they are different sizes so 6 pair total
drwolcot is offline
post #40 of 138 Old 03-22-2010, 09:37 AM
drwolcot
Just thought I would stop by and let you know that I finally started my build thread with my 2WD-->4WD swap here
drwolcot is offline
post #41 of 138 Old 03-22-2010, 12:21 PM
WJChris
WJChris's Avatar
Jerry
I used diluted simple green (50/50) and followed up with some conditioner.
Make sure you scrub good, you will be surprised how good it works.
WJChris is offline
post #42 of 138 Old 05-01-2010, 10:13 AM Thread Starter
JeepsOLot
Ok, finally, an update!! Got the two drive shafts from an '03 GC that looks like it had a pole fall on the roof!, . Talking to Mean Max, and it looks like we'll be going to get the D30 out of it next Thursday, and then next Sat, we'll do the swap, just in time for Mother's Day, ! We'll take plenty of pics to show the entire process. For the prices, the drive shafts were $35 for both, and the D30 will be about $90.
Drwolcot, I got all the bolts and the flat pieces that go between each pair for the front drive shaft when I got it a couple of weeks ago, so, I'm good in that department, thanks for the heads up, !!
More to follow as this progresses,
Jerry
post #43 of 138 Old 05-01-2010, 10:15 AM Thread Starter
JeepsOLot
This worked well, thanks for the tip!!!
Jerry
post #44 of 138 Old 05-01-2010, 10:48 AM Thread Starter
JeepsOLot
Drwolcot, you had a GREAT idea with the GPS unit!!! Eventually, I'll be getting the lower center dash piece with the heater controls and the Spartan Woodgrain trim. I wanted to see how it would look with the ash tray removed and the XM Sat radio in that hole.
This is what it looked like before, and I hated the way it looked:
Here's what it looks like now:
I loved how you can't even see the wires out of the tape deck to the Sat radio! Except for that piece from the 12v adapter, it looks pretty clean!!
Thanks, again, Drwolcot!!
Jerry
post #45 of 138 Old 05-01-2010, 11:35 AM
drwolcot
Yeah no prob. Something you might want to consider since you are going to get the wood grain as extra is try to cut out the ashtray so your xm unit will all be flush (as long as you have steady hands).
Glad to see you are finally making some progress.....its been awhile ha ha! Good luck and keep us updated
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
1995 Laredo Weird "bucking" issues while driving jrsquared ZJ Grand Cherokee Forum 3 07-12-2011 08:20 AM
98 GC Laredo I6 with 4.5" Lift and 32x11.5" tires? Pilzner33 ZJ Grand Cherokee Forum 8 11-27-2010 06:23 PM
"Unintended acceleration" 2005 Jeep Grand Cherokee Laredo mknight WK Grand Cherokee & XK Commander Forum 11 02-23-2010 02:43 PM
"Grand Cherokee" and "Limited" emblems? jdwiseman ZJ Grand Cherokee Forum 14 02-04-2009 07:49 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 07:06 PM
