zj Dana 35 - JeepForum.com
post #1 of 8 Old 10-30-2013, 11:38 AM Thread Starter
zjstevie
zj Dana 35
Now I want to buy 4:56 gears do I need to buy anything else out dies it just fit in and yes I gave a hydraulic press
zjstevie is offline
post #2 of 8 Old 10-30-2013, 05:04 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Please do a search on ring and pinion replacement. Lots to know and special tools needed.
jeepdaddy2000 is offline
post #3 of 8 Old 10-30-2013, 05:10 PM Thread Starter
zjstevie
Where's a good place to look that info on
zjstevie is offline
post #4 of 8 Old 10-30-2013, 09:41 PM
GrouchyTim
Here we go again.
'88 YJ with SOA and SYE and a bunch of custom crap from BWF in Chesapeake.
'97 XJ on 8" lift, double triangulated rear, long arm 3 link front, Eaton/60 with 5.14 gears.
GrouchyTim is offline
post #5 of 8 Old 10-31-2013, 12:11 PM
uberxj92
1992 XJ Cherokee
Originally Posted by GrouchyTim View Post
Here we go again.
Amen. Popping the pop corn now.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #6 of 8 Old 10-31-2013, 12:22 PM
uberxj92
1992 XJ Cherokee
Try the search function on here. Also check Google and YouTube.
First thing you need to find the "carrier brake" for that axle. That way you'll know if you can use the carrier on the axle for the new gears or if you'll have to get a new one that will hold the gears.
you'll need the bearing and seal kit for the pinion. That's tricky to install for the first time but take your time.
You're prolly gonna get the usual Dana 35 debate on here now. So be ready for that.
Is your zj 4wd or 2wd? If its 4wd you'll have to change the gears in the front too.
Why are you going to 4.56?
uberxj92 is offline
post #7 of 8 Old 10-31-2013, 12:22 PM
biffgnar
biffgnar's Avatar
Search Extreme Novice Regear thread. I like that one. IIRC there is a Billavista bible on regearing over on Pirate.
Romney in 2020!
biffgnar is offline
post #8 of 8 Old 10-31-2013, 11:41 PM
Evildriver-3
Just find your local driveline shop and let them do it, or you need a press, torque wrench, inch lb torque meter, calipers, clam shell bearing puller, race instal tool, case spreader. Ask around and see who has the best rep for that work.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
