ZJ Aluminum Dana 44 - JeepForum.com
post #1 of 5 Old 12-08-2007, 08:35 AM Thread Starter
Piper106
ZJ Aluminum Dana 44
Edit. Fat fingered thread title, should be "ZJ aluminum Dana 44"
Need some info on the aluminum Dana 44 rear axle in the 93-98 Grand Cherokee.
Searched here at JeepForum and googled, still some gaps.
Width - wheel mounting flange to wheel mounting flange??
Are they light as feather compared to an iron center section 44 or still a heavy mofo? If anyone has had one on a scale, any actual numbers?
If I decide to look for one in the local salvage yards, were they installed across the board on all the ZJs those years, only certain years, or only with certain engine or option packages??
Piper106
Piper106 is offline
post #2 of 5 Old 12-08-2007, 11:17 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
93-98 Grand Cherokee = ZJ; 84-01 Cherokee = XJ.
WMS-WMS on the ZJ D44a is about 60.5".
I'm not sure about the weight.
The D44a was used in V8 ZJs from 95-98.
Its not a good axle for a swap. It has very limited aftermarket support. Aussie is the only locker available for it and they're not even being made any more.
Wheelin98TJ is offline
post #3 of 5 Old 12-22-2007, 07:39 PM
mecaneck77
The aluminum 44 weighs @ the same as a D35. They have a lot of problems with preload and bearing failures. You would be better off swaping in an iron 44 or maybe an 8.8.
mecaneck77 is offline
post #4 of 5 Old 12-23-2007, 09:32 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
Look for 96-98 ZJs with the V8, the only ones they were used in.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #5 of 5 Old 02-10-2011, 12:48 PM
speedbucket
^wrong
speedbucket is offline
Gear guys - Aluminum housing Dana 44 (D44HD) - excess rotational play? FPKites Tires & Wheels 6 11-02-2008 08:45 PM
Backspacing of stock XJ aluminum wheels vs stock TJ/LJ aluminum wheels (non-Rubi) ? CB3 Tires & Wheels 5 12-27-2007 09:54 PM
Chromed aluminum, polished aluminum or other? red7 Tires & Wheels 4 06-18-2007 01:08 PM
Tig Aluminum 5artist5 Fabrication Shop 9 04-24-2007 08:08 PM
