Zinc Anode in Radiator (thoughts/opinions) - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Zinc Anode in Radiator (thoughts/opinions)
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 07-28-2010, 07:31 PM   #1
RockJeepTJ
Junior Member
RockJeepTJ's Avatar
Ran across Flex-A-Lite's new Zinc Anode (Flex-a-lite 32060 - Flex-a-lite Zinc Anode 1/4"NPT - Quadratec) and was wondering what the opinions were on this subject.
I run a stock radiator in my 2000 TJ Sport (4.0)
Thanks
"Compassion and tact are honorable traits, but are not often found in the bad-guys coming through the wire."
Sgt Rock- Former Sergeant of Marines
MY BUILD THREAD:
http://www.jeepforum.com/forum/f22/r...jeeptj-892796/
RockJeepTJ is offline   Reply With Quote
Unread 05-09-2013, 10:10 PM   #2
CJ7Dac
Bump!!
I'm about to replace my water pump and saw this guy, do they work at all and is it worth it???????
CJ7Dac is offline   Reply With Quote
Unread 05-09-2013, 11:38 PM   #3
5-90
1988 XJ Cherokee
Thanks
It's called a "sacrificial anode," and it works quite well. The idea is used extensively in marine applications (especially saltwater marine,) and most home water heaters made in the last ten years or so have removable/replaceable zinc anodes - check 'em once a year, replace PRN (depending on local water quality, they're good for 3-7 years, usually.)
Why anodes? Because the zinc anodes will corrode faster than the weld metal for the chimney and tank seals, extending the life of the heater tank!
I have no trouble with the idea. I've been kicking around ideas to fit them into RENIX as well, once I get on with the refit of my 88.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote
Unread 05-10-2013, 01:35 PM   #4
Newtons3
Newtons3's Avatar
Thanks
Ive only ever seen them in massive OTR and heavy equipment radiators. I dont know why I never thought to look into one for my personal vehicle. They work extremely well in my experience.
Newtons3 is offline   Reply With Quote
Unread 05-10-2013, 05:50 PM   #5
flying2275
My thought / opinion is to just flush you coolant system every 2-3 years and replace with a 50/50 mix of Zerex G05 and Distilled water and you shouldn't have any problems.
flying2275 is offline   Reply With Quote
Unread 05-10-2013, 06:05 PM   #6
dmill89
1995 XJ Cherokee
^this
I'm sure a zinc anode can't hurt, but coolant (anti-freeze) is loaded with corrosion inhibitors to begin with, so as long as you change it when you're supposed to an anode shouldn't be necessary, and likely won't make much of a difference.
dmill89 is offline   Reply With Quote
Unread 05-10-2013, 06:59 PM   #7
5-90
1988 XJ Cherokee
Originally Posted by dmill89 View Post
^this
So the anode lasts forever.
Consider it cheap insurance - best kind. Once a year, you pull the anode and check it for erosion, just keep another one in your toolbox for if & when.
Unread 05-11-2013, 04:48 AM   #8
Newtons3
Newtons3's Avatar
No. They dont last forever. As stated before, they are sacrificial. They will need to be on an inspection schedule. Specific applications will dictate how often it needs to be changed.
1/4" npt , anode , flex-a-lite , zonc
