YJ Trans swap, BA-10/5 to AX-15 ** Write Up - Page 6 - JeepForum.com
post #76 of 106 Old 03-06-2013, 09:54 AM
lincolnmatthews
2015 JK Wrangler
Great writeup! have just done this conversion on my 87, all good except the roughness from something rubbing or drive line. Thought I would re-read this sticky again for any clues. I don't know if anybody hardly reads this anymore, I may have to send a private mess. to Richmond. But I read when he's almost done he says to tighten up the trans & outrigger, but to leave the outrigger a little loose & not to tighten down real hard. I assume when he says "outrigger" hes talking the rear mount under the TC where the studs stick down thru the skid plate?? right?. I think that this maybe my source, I used the adpt plate from Advance Adpts to re-mount the TC mnt thru the original holes in my skidplate, as I have the early 87 with only one set of holes. I'm also thinking that by using this adpt that it may have raised the whole drive train up by the thickness of this plate, which may contribute to some more drive line mis-alignment??? going to check it out later. My main quest. is what do I leave somewhat loose on the outriggers?? I tightened things down pretty tight including the pos rear mnt from Autozone I just put in, it seems awful hard rubber made in China, I don't know if thats my problem, appreciate any thoughts
lincolnmatthews is offline
post #77 of 106 Old 03-09-2013, 09:48 AM Thread Starter
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
The outrigger needs to be snugged down only. It's meant to move to absorb vibes.
I answered your IM and think you either need an SYE or possibly a MM lift with the TC drop. It's just geometry on the driveline, not the outrigger.
Ernie
- Ernie
Richmond88yj is offline
post #78 of 106 Old 03-19-2013, 07:55 PM
schwag27
i got the same model - 88 YJ with a 4.2 and gathering info for this swap.... when you did your t-case i am confused why did you replace the input shaft but not the input gear as well ?
schwag27 is offline
post #79 of 106 Old 03-19-2013, 08:31 PM
planedoctor
1987 YJ Wrangler
You only need to change the input shaft on the transfer case. The BA-10/5 has a 21 spline output shaft and the AX-15 has a 23 spline(stronger). So rather than change out the trans output shaft, change out the input shaft on the t-case.
planedoctor is offline
post #80 of 106 Old 12-18-2013, 08:54 AM
LIVEWIRE55
ok my question is if i can get a ax 15 with the transfer case on it already, would it not be easier to just leave the tc thats already on it, then to buy a input shaft, and breaking down my old tc. Or does it take some modification to use the ax 15 case?
LIVEWIRE55 is offline
post #81 of 106 Old 12-18-2013, 01:57 PM
planedoctor
1987 YJ Wrangler
Yes, the NP231 is the same other then the input shaft spline count. If you have a transmission and TC as an assembly you can just go with that. Just be aware there were some changes made to the speedo output on the newer units that might not fit your application. The newer ones have a digital output instead of mechanical.
post #82 of 106 Old 12-18-2013, 04:34 PM
jimbos76cj
I'm pretty sure the hole for both units are the same.. You just need the speedo gear from your jeep.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #83 of 106 Old 12-21-2013, 07:12 PM
scottmmb
1987 YJ Wrangler
Okay. If i got a 89 ax15, what stock tcase do I need and when I got that will the stck drive shafts fit?
scottmmb is offline
post #84 of 106 Old 01-18-2014, 04:23 PM
GrEmLiN
1987 YJ Wrangler
http://www.jeepforum.com/forum/f19/y...l#post12716287
See post #51 for more information on which input gear to which transmission/tcase combo etc. as well as Advance Adapters p/n's for swap components.
I've long since completed this swap and I'm not subscribed to this thread, so if anybody needs help, feel free to PM me for info.
Scottmmb, if it's just the trans with no tcase attached, measure how far the shaft protrudes from the back of the transmission. If it's flush or if it sticks out .43" (about half an inch), and then count how many splines it has. If it sticks out half an inch and has 23 splines you're in luck, that's the most common, and nearly any NP231J with a 23 spline input should work. As noted in my post, #51 on page 4, there's three measurements to look out for on the tcase. 1.2", 1.7" and 2.1" -- the 1.7 is for 4cyl or automatics, you'll need the 1.2" if your transmission output shaft protrudes half an inch. I don't think the 2.1" input on the tcase will allow proper mating, but I've never tried. If you're going from a manual trans to manual trans then yes drive shaft lengths should be the same. BA10 and AX15 installed are very similar or same in length. At least I haven't had any issues.
Jimbo is correct, if it has a VSS just place your speedo gear and cable in. It can be tricky to catch the teeth properly.
Any questions in the future, PM me I don't bite.
GrEmLiN is offline
post #85 of 106 Old 01-18-2014, 05:49 PM
jimbos76cj
I was just tearing into a t-case today to pull the chain for a buddy with a broken one and decided to take pics including how to remove the input gear and swap them out. I'll try to get pics up soon if any one is interested. It was very easy to get it swapped.
post #86 of 106 Old 01-18-2014, 05:54 PM
jimbos76cj
You are looking for a 231j from another jeep with the ax-15. Or.. If your lucky you can find one from a xj with a ax-15. No matter what check the spline count before you pick one up. Make sure it's a 23 spline. The other option is to change the input gear on the t-c. If you already have a 231 the gear can be bought for about $100-$125 (I think.. Haven't priced em in a bit) it's really easy to pull the case apart and change it. Took me about an hour to tear one down today to take pics for a write up. Oh and there is a rumor that a few later year ba-10s had a 23 spline t-case. Never seen one but that's the rumor.
post #87 of 106 Old 01-18-2014, 10:02 PM
GrEmLiN
1987 YJ Wrangler
I second what jimbo said, and for what it's worth, instead of looking for a new input gear for my tcase (I used a 92 YJ tcase and 96 XJ AX15) I found a complete tcase, full of water, for $40. Dumped it out, filled it with WD40 and shook it all up, drained, repeat over a couple of days... and it's been working fine for a couple years now.
Also, if anyone is interested, I have a photo gallery up on facebook I can send the link to with a bunch of pictures documenting my BA10 to AX15 swap. The pics are from 2012 when I did the swap but they're still online. You don't need a facebook account to view the gallery. I'm just not too proud of my booger welds and how I ultimately did the transfer case shifter so I'm not about to post the gallery freely yet lol.
If there's a demand, I'll share willingly.
Post or PM.
Also, this might be a good time in this thread to point out for those interested in this swap, YOU WILL NEED A TRANSFER CASE SHIFTER FROM AN AX15 EQUIPPED YJ! An AX5 bracket might work? I have no idea. But the BA10 is not as wide as an AX15, so the tcase shifter bracket will not bolt up properly. You can modify the existing shifter with a little work and planning. I didn't like how I did mine originally but I was likely inebriated at 3am and decided to do the shifter mods then, so I didn't plan very well.
Jimbo, how do you like the Ford Taurus electric fan? Notice a big improvement? How much did it set you back? Which writeup did you follow, if any?
Years and years ago my radiator blew up and I replaced it with a cheap, made in china boogerwelded 100% aluminum radiator from radiatorsus.com or something like that. It was $120-130 shipped to my door, all aluminum with a very good warranty backing it up in case the childlike welding failed. 6 years later it's still working very well, and dropped running temps 5-10 degrees easily. Maybe more my gauge only works when it wants to.
GrEmLiN is offline
post #88 of 106 Old 01-18-2014, 10:49 PM
jimbos76cj
Unfortunately I haven't had a chance to get her on the road yet. As for cost a friend gave me 2 fans for free and I wired it with a 80amp constant duty solenoid and 195 on 165 off (I think) coolant switch. I also added in a 40 amp relay and manual off switch I think I have $80 total I to it.
How did you get the t-case to bolt to the xj ax-15? I thought the tail housing was drilled to clock it 10 degrees down on those.
Please forgive my typos or punctuation, I'm in the front seat of a fire truck with a horrible tire shake.
post #89 of 106 Old 01-19-2014, 12:41 PM
GrEmLiN
1987 YJ Wrangler
Originally Posted by jimbos76cj View Post
I think I have $80 total into it.
Hahah, that last part made me chuckle.
That's a great setup for $80!
Ok I'll post some pictures up to answer your question. I drilled new holes in the XJ transmission.
I was fortunate enough to have a YJ and an XJ AX15 on hand. The YJ AX15 was known to grind, and was internal slave. The XJ was newer, also grinds a little bit, cleaner and above all external slave. The bosses are there on the internal slave trans to punch the holes out and use an external slave. Hard to see in this picture but I started making a template from one and applying it to the other. A transfer case or BA10 could theoretically be used to make this template. This happened to be easiest for me.
XJ transmission, note the location of the holes. If there's "meat" to the right of the holes its an XJ. If there's meat to the left, it's for a YJ.
Using a ballpeen hammer and some shirt cardboard (like you get stuffed inside a dress shirt) you lay it over the holes and tap it to make a mark on the cardboard. It's like a hole puncher almost.
Automatic center punch + Sharpie
GrEmLiN is offline
post #90 of 106 Old 12-02-2014, 07:31 PM
NHYJ4213
I'm looking at buying a 93 yj ax15+Tcase to swap into my 88... Will this basically bolt right up? Im getting bellhousing to tcase... I have a clutch kit with new release bearing and internal slave cylinder (Yes I know external is better, but currently this combo is a killer deal) and I got a new flywheel specific to my motor as well... Do I need the CJ5 304 3 speed pilot bearing, or can I use whatever is normal for he 93 ax15, and do I need a new master, or any other parts? I can't find info on people doing an internal ax15 out of a yj to figure it out myself. Thanks.
NHYJ4213 is offline
cj7 trans swap earlb74 Engines & Drivetrain 3 07-09-2009 09:04 PM
what trans to swap into tj jmx663 Engines & Drivetrain 4 04-30-2009 03:34 AM
NV3550 to AW4 swap. Any good write-ups? mike481 Engines & Drivetrain 0 03-11-2009 08:32 PM
auto trans swap HARLEYX2 Engines & Drivetrain 0 05-29-2006 07:00 PM
95 zj 5.2 engine and trans. swap into a 98 tj 98cheesetj Engines & Drivetrain 8 08-18-2004 08:05 PM
