YJ Trans swap, BA-10/5 to AX-15 ** Write Up - Page 5 - JeepForum.com
post #61 of 106 Old 08-20-2012, 01:24 PM
planedoctor
1987 YJ Wrangler
I used the same clutch that came out of my Peugeot. The clutch has to fit the flywheel you have. A buddy had a clutch out of a AX-15(newer then mine) and the contact points dont line up. I would have had to get a new flywheel also. I didn't have any issues using the stock clutch. I purchased my set up via ebay like this listing. http://www.ebay.com/itm/Jeep-Wrangle...5595b4&vxp=mtr
I got the mounting plate off the ax-15 and modded my skid plate to fit it. You could also just get and adapter plate that advance adapters sells. I'm cheep! The pilot bearing is found at auto parts stores. Just ask for year the transmission came from. If you get a separate transmission the bell housing is usually reasonably priced . http://www.ebay.com/itm/Jeep-WRANGLE...d7812c&vxp=mtr
That kit you listed has a external slave cylinder. That's all well if your going to change master also. I was trying to keep cost down. I already had a new master and slave(internal). As for the input shaft that is the hardest part in my opinion. I was lucky enough to find one on ebay for a steal. I also had to modify the mounting bracket for the 4x4 shifter by cutting down a unused lug on the transmission. Advanced adapters and others sell a bracket that requires no modifications. Hope this info helps.
planedoctor is offline
post #62 of 106 Old 08-20-2012, 03:42 PM
evanjeep
2011 WK
It does. Is the hydraulic lines for the internal slave the same? On the transfer case input shaft should i go with long or short?
evanjeep is offline
post #63 of 106 Old 08-20-2012, 05:19 PM
planedoctor
1987 YJ Wrangler
I used my original slave, master cyl. and their hyd lines. No issues. This site has good reading and understanding. http://www.novak-adapt.com/knowledge/np231.htm and http://www.novak-adapt.com/knowledge...nput_gears.htm Reading this it would seem the long shaft is what your needing.
post #64 of 106 Old 08-20-2012, 07:41 PM
evanjeep
2011 WK
Im looking at this now. It seems the later ba 10 had 23 splines? Either way im gonna need the long one? Thats how im taking the chart. http://www.advanceadapters.com/produ...ded-for-np231/
evanjeep is offline
post #65 of 106 Old 08-29-2012, 02:56 PM
Duvalbulldog
Has anyone encountered the problem of the smaller pilot bearing. A regular pilot bearing puller will not get in there it is too big to get all three prongs in there. Some body help please.
The obvious is usually looked over when the worst is assumed
Duvalbulldog is offline
post #66 of 106 Old 08-29-2012, 03:19 PM
planedoctor
1987 YJ Wrangler
I had to cut, chisel and basically beat the crap out of any I had to remove. I always started with the puller but it never worked. Never had one too small thou.
post #67 of 106 Old 08-29-2012, 06:53 PM
normalicy
1987 YJ Wrangler
Yeah, I've heard quite a few people say that they just had to cut it with a metal cutting hacksaw blade & pry it out once the tension is gone.
What is normal anyway?
E-mail at:
Heatware References (a feedback website)
Ebay Feedback
normalicy is offline
post #68 of 106 Old 08-29-2012, 07:34 PM
evanjeep
2011 WK
I may be doing this next week ill let you know how i get it
evanjeep is offline
post #69 of 106 Old 08-31-2012, 12:45 PM
jimbos76cj
I just did for a buddy's 88.. we found a Ax-15 with the internal slave and small pilot tip.. it was a direct swap, the only real modifications were to get the braket that holds the clutch tube back on we had to grind the corners off of it and had to modify the skid plate. thats it.. Clutch was the same, pilot bearing was correct, threads for the internal throw out bearing was right, the starter bolted right up. Clean easy.. 4hrs worth of work.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #70 of 106 Old 09-02-2012, 01:11 AM
Jkanly
l _____
/l
,[____],
l---L 0lllllll0-
()_)-()_)--o-)_)
Jkanly is offline
post #71 of 106 Old 11-20-2012, 02:09 PM
johnnykind
AX-15 swap
hey guys, I did the ax-15 swap a while back but I am having some problems with the flywheel, my original flywheel ring gear was so chewed up the starter would not even reach it any more, so I ordered a new one, to match the year and engine size of the vehicle,
(88yj, 4.2,- 92 ax15, internal slave)
with the new flywheel for the 88 4.2 the cone on the original starter wasn't even close to the ring gear so I went back to an older style starter ford type, now it starts but makes a horrible noise while it is cranking,
so my question is should I use a flywheel to match the 1988 engine, or the 1992 ax15 trans???
After reading thru the forums for hours on end there seems to be a difference of opinion on which flywheel to use???
can you guys tell me which one I should use and why ???
Johnnykind white jeep club member #421
johnnykind is offline
post #72 of 106 Old 11-22-2012, 01:43 PM
planedoctor
1987 YJ Wrangler
When my teeth were bad I just replaced the ring gear not the whole flywheel. If you change to the newer flywheel you will also most likely have to change the clutch. I was going to put a newer style clutch a buddy had sitting around on mine and when I matched it up the clutch would not work with that old flywheel. The area that the clutch contacts the flywheel is different(well it was for my set up). I have the oem(Autozone) starter, flywheel, ring gear and clutch and newer 92+ pilot bearing, bell housing and transmission.
post #73 of 106 Old 03-01-2013, 08:00 PM
871kevin
What a great writeup. I'm putting an ax15 from a'90 yj with a 4.2L in my 89 yj with a 4.2L. I'm thinking it should go smooth. Does anyone know if my clutch and pilot and my master cylinder will work with new trans?
871kevin is offline
post #74 of 106 Old 03-01-2013, 08:08 PM
jimbos76cj
It's should all swap over.. If your swapping a small diameter input and internal slave into your jeep the. Is should not be a problem.. Only difference between the units will be the trans mount in the cross member. Try to get the cross member from the jeep the ax-15 is from. If not you can cut yours to make it fit:
post #75 of 106 Old 03-02-2013, 03:41 AM
871kevin
Yeah I'm going to try and get the cross member. And as far as I can tell I shouldn't need the master cylinder because I'm going from internal slave to internal slave. Is that correct?
871kevin is offline
cj7 trans swap earlb74 Engines & Drivetrain 3 07-09-2009 09:04 PM
what trans to swap into tj jmx663 Engines & Drivetrain 4 04-30-2009 03:34 AM
NV3550 to AW4 swap. Any good write-ups? mike481 Engines & Drivetrain 0 03-11-2009 08:32 PM
auto trans swap HARLEYX2 Engines & Drivetrain 0 05-29-2006 07:00 PM
95 zj 5.2 engine and trans. swap into a 98 tj 98cheesetj Engines & Drivetrain 8 08-18-2004 08:05 PM
