Yj regearing questions - JeepForum.com
post #1 of 6 Old 09-17-2012, 11:44 AM Thread Starter
rlou315
I got a 94 yj with a 4 banger and 2.5L, and i want to regear so i can push some 35s on it
1. what regear ratio should be good for a daily driver? i'm not a speed demon so 65-70 mph should be good.
2. is it possible i can do it at home? I've looked online and i could not find a tutorial on how to do this
3. What do i need to do this? any parts i need to buy or hardware?
Thanks guys!
rlou315 is offline
post #2 of 6 Old 09-17-2012, 05:12 PM
BlueRubiconrich
regearing is a big job better left to a shop.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 6 Old 09-17-2012, 09:19 PM
ltrail
1984 XJ Cherokee
^ he speaks the truth here. While costly, setting up your own gears with the questions you asked will prove more costly when redone. Not for the faint of heart so to say. If one was to want to learn I'd say get a Toyota or similar 3rd members and learn in an easy one. For the application you are shooting for a case spreader, dial indicators, gear paint, setup bearings, bearing pullers, and a few other things that will run the tab up past the cost of the gears and setup from reputable driveline shop. After all this the gears won't carry warranties unless you send all setup specs to manufacturer afterwards.
Be prepared. You need a darn good understanding of what is going on there to complete this successfully. Did my own gears, but even with the tools and a friend to help it wasn't easy.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 6 Old 09-18-2012, 10:51 AM
RWKHaus
1990 XJ Cherokee
you already have 4.11's (unless it is not stock gearing).
SO you would need to go up to a 4.88 (the highest you can go with your axles you have now).
You do not need carriers at least.
Just gears and master kits.
This is really something you should pay the 250-1000$ to have done by a Diff guy.
Where r you located?
Brook "He kissed me at KOH, you should ask him about itů"
RWKHaus is offline
post #5 of 6 Old 09-18-2012, 12:22 PM
ltrail
1984 XJ Cherokee
The proper bearing tooling will cost you half of a regear.
ltrail is offline
post #6 of 6 Old 09-19-2012, 04:20 PM Thread Starter
rlou315
I'm located in Union County in Jersey. And thanks, i didn't know there was so much work into this. I haven't found much information until now
rlou315 is offline
engine , regear , YJ
Regearing help copestraight General Jeep & Off-Road Equipment 12 08-08-2011 09:49 PM
regearing D30 drew76924 Engines & Drivetrain 6 01-31-2008 07:18 PM
regearing king_kong General Jeep & Off-Road Equipment 9 04-30-2007 08:08 AM
Regearing ben_stewart Engines & Drivetrain 1 12-01-2006 03:00 AM
regearing 83 cj-7 258 Tires & Wheels 2 07-02-2004 07:08 PM
