YJ Rear Axle in YJ? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > YJ Rear Axle in YJ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 05-31-2006, 12:37 PM   #1
00Vert
YJ Rear Axle in YJ?
I had a Jeep guy tell me that I should put a XJ (Cherokee) rear axle in my Wrangler (YJ). Is this swap, although relatively cheap and easy, worth it? I am running 31" tires with stock lift.
Thanks, Phil
00Vert is offline   Reply With Quote
Unread 05-31-2006, 12:56 PM   #2
Johnny World
Thanks, Phil
It depends on what year XJ the axle is coming from.
This is taken from the XJ FAQ:
Dana 35: XJ (most 84-91, all w/ABS post-91)
Chrysler 8.25": XJ rear, non-ABS post-91
Dana44: Some 1987-89 XJ Cherokee rear (most common in 1987 w/towing package, very rare in later models)
If it's an XJ with the Dana 44, then I would says it's worth it. Not too familiar with the Crysler 8.25" so can't help you there.
[U][B]'02 WJ[/B][/U], Laredo Special Edition, 4.0L I6
Johnny World is offline   Reply With Quote
Unread 05-31-2006, 12:57 PM   #3
MuddyV8YJ
not unless youre replacing a d35 with a chry 8.25.
'91 YJ. Slightly Modified
'04 WJ. Columbia Edition 4.7 HO. 2" BB, 2" OME. 265/65/16 Icelander MT
MuddyV8YJ is offline   Reply With Quote
Unread 05-31-2006, 01:12 PM   #4
00Vert
Is this a pretty good route? Is the Chrysler 8.25 much stronger than the stock D-35? Is it an easier install than the Explorer 8.8?
Thanks, Phil
