If i was you I would try and gain about 4" of lift to clear 33s. First i would buy any combination of suspension lift kits to gain 3" of lift, the best one I know of would be the rubicon 2.5 in" kit, with 1/2 in shackles. Then buy a 1 in" body kit. You will be able to clear 33s. This is the perfect set up for someone like yourself, but of course the 4" of lift would cost you about $750 (550 RE, 100 shackle, 100 body)
You could always go straight to a 4" suspension lift, but that would mean you would probably need a slip yoke eliminator kit, which can range from $350 to as much as $800. Plus the 2.5" kit is complete, and will not effect handling that much, and will provide a better ride. Usually if you excede about 3.5" of suspension lift, you will encounter adverse effects to your handling, and overall ride.
It's all about trade off's
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
