Yj idle issue?!?? - JeepForum.com
post #1 of 18 Old 08-16-2013, 05:33 PM Thread Starter
88yjfloridaboy
Yj idle issue?!??
I am a daily visitor to this site and credit most of my knowledge to these forums. So i have done many repairs following what others have said. But i have had an ongoing issue for about a year now. Anytime i take my jeep offroading and drop it into 4 high i can run it for about 10-15 min then when i let off the gas my idle drops from 800rpm in drive to 300rpms and continues to slowly decline until it stalls out. And everytime after that i can crank it over but then it dies. I have had the carter carb rebuilt twice and sprayed. The idle jets frequently and still no luck. It has new gas tank new sending unit, fuel pump, filter, and done the nutter bypass. Is there anything im missing or is it that carb
88yjfloridaboy is offline
post #2 of 18 Old 08-16-2013, 05:38 PM Thread Starter
88yjfloridaboy
Also has new thermostat, flushed radiator, new plugs and wires, timing has been adjusted. Also in 2wd driving around town it runs fine. Ive noticed it only gives me problems when i run it in 4x4. Not sure if that helps just figured id explain as much as i can
post #3 of 18 Old 08-16-2013, 08:23 PM
Shotgun123
1987 YJ Wrangler
I don't know what year your is but I had a 1987 that wss doing the same thing.... it just blew up.. the 1987 motor I just bought. has a carburetor upgrade non-electric... I was told that the electric one girls are junk. and you can't do much with them.
Shotgun
Shotgun123 is offline
post #4 of 18 Old 08-17-2013, 07:01 AM Thread Starter
88yjfloridaboy
Its an 88 and ur talking about the stock carter carb right?
post #5 of 18 Old 08-17-2013, 07:04 AM
Billy
Get a clean air filter. :thumpsup: (seriously though)
lol anyway...I quit dealing with jeeps with carbs. I just don't have the patience. good luck.
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #6 of 18 Old 08-17-2013, 08:36 PM
uberxj92
1992 XJ Cherokee
Where in Florida? Lake county here. The humidity down here will definitely toy with your Carb.
You said in 4x4 is when it acts a fool. Are you flexed or steaming in the water. Carbs are notoriously finicky about angles and steam.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #7 of 18 Old 08-17-2013, 09:47 PM Thread Starter
88yjfloridaboy
Lee county. Ya this humidity is bad. What do u mean flexed or steamed? Lol
post #8 of 18 Old 08-18-2013, 06:23 AM
uberxj92
1992 XJ Cherokee
If you have the girl leaning over in a hole or obstacle, the Carb will start loosing fuel.
Steamed...if you hit water and it steams off of the hot jeep. The Carb will suck in the steam. Steam doesn't burn like air.
How's your fuel pump and filter?
uberxj92 is offline
post #9 of 18 Old 08-18-2013, 07:00 AM Thread Starter
88yjfloridaboy
Oh gotcha ya that makes sense. It has brand new fuel pump and filter. The only thing in the fuel system i didnt replace was the lines and the carb. Ik the idle tubes were being drilled out on that model. But i wasnt sure if maybe there were vaccum lines that were for the 4x4 only or anything like that. Plus another problem ive been experiencing too is i have to pump the gas quite a few times to get it started cold
post #10 of 18 Old 08-18-2013, 07:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
http://www.jeeptech.com/engine/carter.html
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #11 of 18 Old 08-18-2013, 08:18 PM Thread Starter
88yjfloridaboy
Ill give that a shot tomorrow. Thanks man. Has anyone drilled out the tubes and noticed a dramatic difference
post #12 of 18 Old 08-18-2013, 08:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Probably 100 times at the dealership when the Eagles, Concords, Spirits, Gremlins, CJs and YJs had idle issues.
post #13 of 18 Old 08-19-2013, 06:39 AM
uberxj92
1992 XJ Cherokee
Lol. Just get a 4.0 put in your crank and rods. Problem solved. More power better MPG EFI. LOL. just teasing
uberxj92 is offline
post #14 of 18 Old 08-19-2013, 06:32 PM Thread Starter
88yjfloridaboy
Quick update, cleaned out the tubes and man almighty what a difference. I think the next time ill have to clean them ill drill them out. The idle tubes are the copper looking tubes though right? Not the screws with the holes in them?
post #15 of 18 Old 08-19-2013, 06:40 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep. There is a drill size for them but I forget it right now. Pretty much the first or second bit that won't fit in the hole---use it.
