XJ to YJ Engine Swap, PCM Swap Necessary? - JeepForum.com
post #1 of 2 Old 10-01-2010, 09:50 PM Thread Starter
md93yj
I'm buying a 93 YJ which had an engine swap with a 94 XJ. Do I need a 94 XJ ECM to install in the YJ to run the engine or will a YJ ECM work on the XJ engine?
md93yj is offline
post #2 of 2 Old 10-01-2010, 10:51 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The PCM does not know or care what vehicle the block came from. If your YJ sensors, intake, exhaust, and distributor (anything else as needed) are installed on the XJ block it should run.
CJ7-Tim is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
350 engine swap? 88Blackwrangler Engines & Drivetrain 1 04-05-2005 10:06 AM
swap engine halfline Engines & Drivetrain 4 11-15-2002 07:35 PM
